Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 02-13-2015 | 03:21 AM
  #1381
cczjordan's Avatar
Originally Posted by cczjordan
After fully broken in, what is the shimming for 25%, p3/p4 plug, ambient temp 28-33°c
Guys, any advise?
cczjordan is offline
Old 02-17-2015 | 01:50 PM
  #1382
Guys, any advise?
I take the Brake in Shim out and Then Run a P3 Plug Has always worked well for me. Have one of these engines in my Truggy for almost 8 Months. It Rocks!
tcb22185 is offline
Old 02-17-2015 | 07:22 PM
  #1383
cczjordan's Avatar
Anyone experiencing high temp with os2060 pipe, fuel economy was excellent. Guess i switch back to arrow 2103 pipe
Old 02-19-2015 | 06:12 AM
  #1384
No i always have used the Aarow Pipe.
tcb22185 is offline
Old 02-21-2015 | 01:54 AM
  #1385
cczjordan's Avatar
In buggy with 2103 pipe, usully how many minutes can get?
Old 02-21-2015 | 03:45 AM
  #1386
Mine will run 11 to 12 minutes.
xxxntwv is offline
Old 02-21-2015 | 03:47 AM
  #1387
AP3XMONK3Y's Avatar
looking to pick up one of these engines but don't know if to get the v4gtr or the gtr plus. i will be running it in a buggy, any advice greatly appriciated .
AP3XMONK3Y is offline
Old 02-25-2015 | 12:17 AM
  #1388
cczjordan's Avatar
Gtr plus, more aggressive. Fuel consumption almost same? But more power = higher fuel consumption
Old 03-31-2015 | 09:24 PM
  #1389
gtr plus orion 2013 at about the half gallon mark almost able to turn over by hand, p3 plug traxxas top fuel 20% getting 10min exactly.. couldn't be happier with this engine.
furn1593 is offline
Old 06-13-2015 | 05:29 PM
  #1390
Autocratic's Avatar
What are the factory carb settings? Having a hard time getting a good tune on this motor and want to start over needle wise.
Autocratic is offline
Old 06-13-2015 | 10:11 PM
  #1391
swop77's Avatar
I had a hard time tuning it till I found here that the mid needle should be out 2 turns from flush.
Low I usually start with flush high with 2 1/2 turns out from closed. Should be somewhere posted from vppro in this thread.
swop77 is offline
Old 06-14-2015 | 08:48 AM
  #1392
Autocratic's Avatar
Well I figured out what my tuning issues were.
After taking apart the motor I found the case was cracked at the mounting tab, lengthwise. Small air leak causing it to run hot and stall out.
Probably just going to order a whole new motor. Get the Plus version this go around and order a new case later on as a backup.
Old 06-14-2015 | 11:50 AM
  #1393
swop77's Avatar
Had that happen before, replaced it with a os case, it also cracked. After a while my motor was arrow / ninja / os Frankenstein. Still run it in a truggy after prob 8 gallons. The arrow gtr plus v4 is a strong little beast after two gallons in my buggy.
swop77 is offline
Old 06-19-2015 | 07:34 PM
  #1394
Autocratic's Avatar
Do you still have the break-in shim installed?
Old 06-19-2015 | 10:27 PM
  #1395
swop77's Avatar
Yes I do. Prob take it out this weekend.
swop77 is offline
