Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 06-28-2013 | 09:32 PM
  #1231
grim rc's Avatar
Here's the deal I have a gtr 3port modded and I have not ran or broken the motor in yet. I also have the same motor not modded but I am currently running it in my zo1B. My ?s r has any one ran one of these modded? And if so how does it run? How did u break it in? What restrictor is being used? And what chassis is it ran on trug or bug? I plan on breaking in the modded one in very soon and I would like some input please.
grim rc is offline
Old 06-29-2013 | 05:50 PM
  #1232
rcmania74's Avatar
Has Anyone Else Bought The New Pipe Yet? Curious To Here opinions
rcmania74 is offline
Old 06-29-2013 | 06:04 PM
  #1233
Pharcyed's Avatar
Got one on the way just now, I will post results when I get them. I have had good results with the VP-Pro RS-1 and RS-4 pipes with this motor so far.
Pharcyed is offline
  #1234
http://www.rctech.net/forum/r-c-item...l#post12302370
Great engine
gixxer420 is offline
Old 06-30-2013 | 05:20 PM
  #1235
i recently got one of these engines the other day taht had basically only had the break indone. currently its only had about 3 litres on it. it seems i have the V1 carby on it tho because i cant get it to "rich bog". i have the top and bottom needles almost flush and the engine is still lean.
what other carbies can i put on this? preferably not the OS 21J cos it is worth more than i paid for the engine.
brendon.matt is offline
Old 06-30-2013 | 06:03 PM
  #1236
VPProUSA's Avatar
Set the mid range 2 turns out from flush pointing at 2 o'clock. Then the Arrow V1 and V2 carbs will run just like an OS and idle for days.
VPProUSA is offline
Old 06-30-2013 | 08:06 PM
  #1237
i have done this and then set the HSN and LSN so rich they are almost falling out and i still cannot get it to blow smoke, the engine is lean and if i put my fingers over the needles the engineblows shitloads of smoke and dies in 2-3 secs.
Old 06-30-2013 | 08:21 PM
  #1238
sschultz's Avatar
Sounds like bad orings on the needles....
sschultz is offline
Old 07-01-2013 | 07:04 AM
  #1239
VPProUSA's Avatar
Yes, install a new o-ring kit. OS o-rings will also fit. Then put a drop of thread lock on all the needles so they do not vibrate loose.
VPProUSA is offline
Old 07-01-2013 | 05:47 PM
  #1240
stallen50's Avatar
I recently put the 3+2 sleeve,rod and piston set in a new arrow crankcase. I can get it to idle, but once I try giving it gas it dies. I have tryed every needle setting they all have the same effect. Any help? The motor bearings are all new same as clutch and clutch bell bearings. Anyone else put the 3+2 sleeve in? The sleeve barely sits flush in the case. And can't get to go any farther.
stallen50 is offline
Old 07-01-2013 | 05:59 PM
  #1241
Check the shims and see how the compression is.
george919 is offline
Old 07-01-2013 | 06:19 PM
  #1242
stallen50's Avatar
The compression is tight. Because its new. The shims are how they come from the factory
Old 07-02-2013 | 05:09 PM
  #1243
stallen50's Avatar
Any help?
Old 07-02-2013 | 05:28 PM
  #1244
VPProUSA's Avatar
I have no idea unless you put the sleeve in backwards. It ran fine in my old arrow GTR-21. The sleeve is supposed to sit above the case, same as with the 3 port sleeve.
VPProUSA is offline
Old 07-02-2013 | 06:30 PM
  #1245
stallen50's Avatar
The slot in the sleeve is aligned with the pin in the front like it should. I was able to get to throttle up but still not running right. What is the factory needle settings again?
