Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 02-15-2012 | 07:38 AM
  #481
stallen50's Avatar
Originally Posted by twitch_1
Whats the power band like on this motor eg smooth or aggressive?????
power band is smooth but peppy.lol
stallen50 is offline
Old 02-15-2012 | 07:40 AM
  #482
stallen50's Avatar
similar to the old os v-spec
Old 02-15-2012 | 05:17 PM
  #483
Ok thanks for that i never really drove the old v-spec much but have heard it's a little aggressive bottom end....
What would be a good pipe to runn on it i have a 2035 and a hong nor 2080, or would i need to get another pipe???????
twitch_1 is offline
Old 02-15-2012 | 07:05 PM
  #484
stallen50's Avatar
2035 would be a good one to run. it would be a good all around pipe for u
Old 02-15-2012 | 08:26 PM
  #485
power band is smooth. responsive engine.
pcage is offline
Old 02-16-2012 | 01:06 AM
  #486
Thanks guys i might have to keep this motor in mind....
twitch_1 is offline
Old 02-17-2012 | 11:58 AM
  #487
Default plug
has anyone run it with an odonnell97 plug, i am going to try to get through the heat cycles at least with one. and then switch to p3 if necessary!
randystang is offline
Old 02-17-2012 | 12:45 PM
  #488
stallen50's Avatar
yes you can run it with od97t plugs. i would suggest you get a p3 plug. as they tune kind of hard with odonnell plugs unless you can get the hot plugs
Old 02-17-2012 | 05:44 PM
  #489
run P3's with this engine and you will have no problems, Use breakin shim for about 1 to 1.5 gals and then take out and re tune.
Engine is fast even with break in shim in.
Enjoy
OoD1S is offline
Old 02-18-2012 | 03:19 PM
  #490
Can i use the os xzb con rod
In the arrow gtr?
rossham46 is offline
Old 02-20-2012 | 02:30 AM
  #491
I am afraid it doesn't fit. XZB is long stroke. Arrow is short stroke.
pcage is offline
Old 02-20-2012 | 02:43 AM
  #492
Rsickles's Avatar
In the arrow gtr?
Yes, it'll work.
The stroke is determined by the crank. The rod is the identical length on VZ and XZ platforms.
Rsickles is offline
Old 02-20-2012 | 02:00 PM
  #493
Please disregard this message in it's entirety. I was mistaken.
Eivind E is offline
Old 02-20-2012 | 10:05 PM
  #494
Originally Posted by Eivind E
Made the mistake of accidentally buying a Gen 1 version of this engine from ebay seller "atomrc" who conveniently neglected to mention that the case on Gen1 was a dud, and that the o-rings were the wrong size on the carb.
So question is now, how do I get the updated Gen 2 case and o-rings?
I feel a bit cheated, the seller made sure to write "2011 version" but conveniently neglected to mention the flaws.
You would hope if it's a manufacturing defect that Arrow would cover it no matter where you purchased your new engine from.
John. is offline
Old 02-20-2012 | 11:45 PM
  #495
The Gen 2 carb isn't a work of art either. Rc willpower on ebay auctions O.S.xzb carbs and they consistently go for about $25. Thats probably cheaper than replacing the o-rings and you have a much smoother carb. Hobby pro sells the new case. I think the problem with the gen 1 case was the loose bearings but not all of them had the problem. Check and see if you've got a bad one.
Edit. Hobby pro also has the o-rings and for only $7.99. Case w/o bearings is $62.39 and with bearings is $89.99
Khanuen is offline
