Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 11-21-2011 | 10:41 PM
  #331
Jaz240's Avatar
you cannot replace the bearing as its the case that is too big, not the bearing being too small. Also the V1 engine had O-rings in the carb that were too small. If I were you I would not even run it until you get the V2 case and O-rings
Jaz240 is offline
Old 11-22-2011 | 06:29 PM
  #332
R/C Lidz's Avatar
Originally Posted by photobrat
Im about to pick up a nib "used" gtr, how can I tell if it has the updated v2 crank case, and of its v1 is that a big deal performance wise? When did this change over happen? THANKS!
umm...
R/C Lidz is offline
Old 11-22-2011 | 07:01 PM
  #333
photobrat's Avatar
Originally Posted by R/C Lidz
umm...
New second hand, never ran, not from a dealer. Found out it's V2, so all good.
photobrat is offline
Old 11-29-2011 | 11:29 AM
  #334
VPProUSA's Avatar
Default Arrow-Racing GTR-21 - $199.99
Cyber Week Special
Arrow-Racing GTR-21 Ver II
$199.99, Save $35
VPProUSA is offline
Old 11-29-2011 | 11:31 AM
  #335
VPProUSA's Avatar
The new case says "Arrow Power" around the front crank bearing.
VPProUSA is offline
Old 11-29-2011 | 07:13 PM
  #336
bigjayjay1's Avatar
Originally Posted by roblupo
The case was changed a few months back due to the front bearing coming out really easy. If you take the engine apart, and you pull the crank out and stick a wrench in the case and hit the front bearing it will fall out.
The bad thing with this is air leaks and fuel leaks from the front bearing. Also it does not seem to have the power of a sealed engine. You can replace the bearing, or get the new case from Hobby Pro and put all the parts you have one the new case.
Are they replacing the case for free?
bigjayjay1 is offline
Old 11-30-2011 | 06:00 PM
  #337
VPProUSA's Avatar
If you bought it at Hobby Pro USA or one of our official dealers, then yes. Shoot us an email sales @hobbyprousa.com.
VPProUSA is offline
Old 12-06-2011 | 11:30 AM
  #338
VPProUSA's Avatar
VPProUSA is offline
Old 12-06-2011 | 11:34 AM
  #339
VPProUSA's Avatar
Ryan Lopez finishes 2nd place with the Arrow GTR-21 Ver II at the Fall Brawl.
VPProUSA is offline
Old 12-13-2011 | 07:26 AM
  #340
stallen50's Avatar
what are you guys running for pipe on this engine for good power and run time?
stallen50 is offline
Old 12-13-2011 | 08:23 AM
  #341
Jaz240's Avatar
From the research I did the best pipe is Nova 9901. After that the OS 2050 or Losi RE-11 (may be the RE-10 I forget) or the OS 2060 or other Losi pipe.
One of the local racers went 12 minutes in buggy with the Nova 9901 pipe and from what I saw there were no dead spots in the band
Jaz240 is offline
Old 12-13-2011 | 03:16 PM
  #342
R/C Lidz's Avatar
If it's a VZB clone why does a Nova pipe work best? Seems a 2050/2060 would be the perfect match
R/C Lidz is offline
Old 12-13-2011 | 03:33 PM
  #343
photobrat's Avatar
James, do you have this engine?
Old 12-13-2011 | 05:00 PM
  #344
Jaz240's Avatar
I'm not sure, but a close friend did some pipe testing and settled on the 9901. I saw it in action and I saw him run his buggy 12 minutes until dry. There was excellent power everywhere he needed it and this was a very large 8 scale track.
Yes I do but have not run it yet. It is in my pit box waiting on break in. I have a few good working engines so I decided not to rush into getting this one all dirty. Over the last year I have sold about 40 of these engines. Some local, but most shipped. I have gotten all kinds of feedback, from the worst engine ever, to the best thing since sliced bread. The first few batches had the bad cases and carbs, so there was lots of grumbling at that time because IMO the engine was crap. How can any engine be good if you cant tune it and the bearings are spinning in the crankcase? Once the issues were resolved ( about 6 Months ago) This engine has been getting nothing but raves from everyone I have sold it to and also everyone who is using it. If you look around there are a few PRO drivers running this engine. Thats not something you would see unless they can perform with the best of them. I am looking forward to running it and I will be using the nova 9901 pipe with the half moon header, but I dont like to store perfect running engines so I'm waiting till I have a need for it.
Jaz240 is offline
Old 12-22-2011 | 01:37 PM
  #345
Hobby Pro USA
Guest
Posts: n/a
For run time, use an OS 2060, Nova 9901, or Losi RE-12. I am sure there are others, but I have heard good things from Arrow drivers on all 3 of these pipes.
