Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 05-21-2011 | 06:19 PM
  #181
Jaz240's Avatar
Cool. Keep us posted
Jaz240 is offline
Old 05-21-2011 | 08:07 PM
  #182
Just got mine today and the quality is there man,thing looks great! Will be breaking mine in soon!
BeefHead is offline
Old 05-21-2011 | 11:14 PM
  #183
here's my setup
6.5mm restrictor
nova 9901 pipe w/ 41021 headder
sidewinder strike 30%
steel flywheel 2 comp w/green springs, 2 alu w/ gold springs (std losi setup)
os p3 plug
13/48 gear ratio
motor has about 1 gallon on it, and i took out the break in shim before the race
we ran a 20 min main, came in at 10 min, and took only 100cc, I used a Losi fuel gun.
Hope this helps
akiyama77 is offline
Old 05-23-2011 | 12:09 PM
  #184
where would be a good place to buy this engine online ?
thks
crosten is offline
Old 05-23-2011 | 12:26 PM
  #185
STUBYSLAP31's Avatar
R/C Tech Elite Member
vp-pro-usa.com
STUBYSLAP31 is offline
Old 05-23-2011 | 12:52 PM
  #186
godirt's Avatar
Answerrcusa.com
godirt is offline
Old 05-24-2011 | 06:23 AM
  #187
Mark Erce's Avatar
Default after 1 gallon...
ok guys well I got about 1gal swallowed up by my Arrow. I ran it all weekend at the Rc Pro Series in St.Louis. weather was steadily changing from cold and rainy to hot and humid at the end of the week. track was med size(170X75), smooth and damp at first then slowly started to dry out and groove up. all i gotta say the engine worked superb,,,absolutely zero hiccups, no flame-outs, great smooth and clean power band, and would idle all day long if you let it
here's a few pics of the piston and sleeve after 1gal. I'm running a 6.5mm nova insert, )OS P3 plug, and VP-Pro RS-1 pipe and Byrons 30/11 fuel. I run a Agama buggy with stock clutch setup. I will be taking out the break-in shim and start race tuning it and monitoring my lap times now that its broken in. I'll keep you guys posted.
Mark Erce is offline
Old 05-24-2011 | 08:55 AM
  #188
scrapsz's Avatar
Received one of these engines used in good condition. There's a shim in the box, is it safe to assume this is the 'break-in' shim?
The mechanical pinch is pretty much gone. Currently mated up with Pavidis 2050 pip...run times are around 8 min. Engine performs fantasic...using 8mm restrictor, going to try the 6.5mm & 70% WOT to see if run times improve.
scrapsz is offline
Old 05-24-2011 | 09:23 PM
  #189
killerkustoms's Avatar
Yes thats the break in shim, but pull the head just to check how many shims are there. Because I didn't use the break in shim included just put one from my spare parts bin.
killerkustoms is offline
Old 05-25-2011 | 05:21 AM
  #190
scrapsz's Avatar
Thanks killerkustoms. What is the 'race tune' setup...1 thick and 1 thin shim?
scrapsz is offline
Old 05-25-2011 | 07:08 AM
  #191
Mark Erce's Avatar
there's a 2mm(silver) shim and 2(copper) 1mm shims. always keep the silver one and one of the copper ones in at all times. the extra copper one is for break-in. you can remove it after about a gallon.
Old 05-25-2011 | 12:16 PM
  #192
scrapsz's Avatar
Perfect...thanks Mark! The engine has one silver and one copper installed with another copper in the box. I guess the prior owner didnt install the break in shim.
scrapsz is offline
Old 05-26-2011 | 11:08 AM
  #193
Mark Erce's Avatar
thats correct. they all come with the 1 silver and 1 copper one installed. maybe the previous owner took it out after he broke it in? does it look like its been used?
Old 05-26-2011 | 11:26 AM
  #194
Mark Erce's Avatar
thx James for the C-Rod. Super fast shipping like always!!!
Old 05-26-2011 | 12:58 PM
  #195
JamminSP's Avatar
Im only running 1 thin copper shim..
I did switch to the 2060 pipe and noticed my fuel economy increased. Im at about 9 1/2 to 10 minutes per tank now so Im happy... That was almost a 3 minute increase by simply switching the pipe..... Performance is still as smooth and crisp as with the 2050 though....
JamminSP is offline
