Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 05-10-2011 | 11:11 AM
  #166
so whats the "street" price on this and where can I get one?
Neesh is offline
Old 05-10-2011 | 11:34 AM
  #167
Jaz240's Avatar
Sent you PM
I also have parts in stock:
Carb O ring kits and con-rods
Jaz240 is offline
Old 05-17-2011 | 07:44 PM
  #168
Mine will be hear in a week but it will be a couple of weeks till I can race it.Our local track is doing a rebuild for an upcoming big race.Will give me lots of time to break her in. Going to try a thunder tiger 2035 pipe(my fave pipe of all time lol) Will see how it goes.
BeefHead is offline
Old 05-21-2011 | 12:29 PM
  #169
What plugs are people using with the Arrows engine?
Is the taper only suited to OS plugs?
David1976 is offline
Old 05-21-2011 | 01:01 PM
  #170
godirt's Avatar
My favorite plug here in texas is the odonell 97t it works great for me, my friends love p-3 and p-4 from os also.
godirt is offline
Old 05-21-2011 | 02:10 PM
  #171
Jaz240's Avatar
Team Terribles driver Brandon Akiyama was Getting ridiculous run times last night! 6 minute qualifiers with over half tank of fuel left when finished! This engine has it all. Power, smoothness, steady idle, insane run times, etc, etc and it was a huge track with 70% WOT.
Jaz240 is offline
Old 05-21-2011 | 02:31 PM
  #172
JamminSP's Avatar
Details..... Which pipe, restrictor, etc??? I have been running one that has just now crossed the 3 gallon mark. With the 8mm restrictor and a Losi re11 pipe I have only managed to get 7-7 1/2 minutes....
JamminSP is offline
Old 05-21-2011 | 02:38 PM
  #173
Jaz240's Avatar
Not sure on the restrictor but I know he is using a Nova (9901) pipe I think.
I am sure he will be on to answer your questions.
Jaz240 is offline
Old 05-21-2011 | 02:45 PM
  #174
Are the tapers different on the plugs? I am just worried about sealing. I was always under the impression that OS plugs have a unique taper?
Old 05-21-2011 | 03:00 PM
  #175
JamminSP's Avatar
Thanks man... I really do like how smooth the engine is.... But Im liking the Alpha run times... If I can get close to 10 minutes I will run this engine more than I do now..
JamminSP is offline
Old 05-21-2011 | 03:12 PM
  #176
Jaz240's Avatar
do you pull out the break in shim? The 8MM restrictor is too large. Go to 6.5 what fuel are you running? Lower your Throttle EPA to 70%..anything more than that is just wasted power and fuel. also, check your idle. The idle gap should be just a tic opened. somewhere around .3-.4 MM. Use a colder plug like P4 or P5 and then tune around your idle and plug. You would be amazed what happens when its all set up properly..PS. These methods work with all engines.
Jaz240 is offline
Old 05-21-2011 | 03:18 PM
  #177
JamminSP's Avatar
Im running the thinnest shim, have recently installed a 7mm restrictor and am only using about 60% of the throttle throw. Im running VooDoo 30% nitro and a VooDoo #6 plug (p4) I had heard also that the RE10 pipe was a better suit for this engine but havent had the chance to try it.
JamminSP is offline
Old 05-21-2011 | 05:02 PM
  #178
Excellent motor at an excellent price. ; )
Andrew Smolnik is offline
Old 05-21-2011 | 05:37 PM
  #179
Jaz240's Avatar
Well your ambient conditions are similar to AZ so it can only be the pipe, your track surface, your trigger finger or your tune. Try negative expo on your throttle servo. That may help smooth things out and get you better run time. There are never any guarantees that one guys 10 minute engine will get the same run time from another driver on another track, but so far everyone but you is claiming fantastic run times with this engine so I think there is a reason for that.
Jaz240 is offline
Old 05-21-2011 | 05:42 PM
  #180
JamminSP's Avatar
Im thinking the pipe... Just kinda wanted to see what everyone else was running. Im fairly smooth with the throttle finger and its much easier to be smooth with this engine. The next club race i will try a little more in depth research as far as different pipes and will try the 6.5 restrictor....
JamminSP is offline
