Arrow Racing GTR .21 Engine Thread
#1006
CKmaxx...I think I know what Im doing, ive' own tons of RC engines, what Im saying is this engine is tighter than any other Ive had, you can't say you never felt the compression on a new engine so don't go there! With that being said, my engine came in the pinch zone, thats why I was wondering why I couldn't get it to spin over!
#1007
Do whatever tickles your pecker then.....
#1008
I did some more checking, and on the crank case of a Go Engine, the O-ring clearly protrudes about .5mm or maybe more, from the case. If you stick a hex driver down there it will stop on the O-ring.
However on the Arrow it did not protrude at all, and the hex driver does not catch on the O-ring.
So basicly the O-ring in my Arrow crank case is useless
I wouldn't want to try and run it like this.
I also noticed that the large O-ring on the back plate doesn't seem to be any good either. Did they all come like this? Like I said this is a new engine.
At the same time I had a Novarossi with a terminal condition, so I fitted the carb from that in it
When I inserted it in the crankcase, it now stops at where the o-ring is, and then I squeezed it in further, so I think this new Go engine o-ring did the trick.
This o-ring is part number "Go or-0004".
I also fitted the Go engine o-ring for the backplate. The backplate now goes in real hard, so obviously this seals up well.
Stuck the 0.1mm shim in for break in. And then I spent a good 45 minutes filing off the rear right corner of the mounts so it will fit a kyosho
As soon as the rain lets off I'll be breaking it in
I have to say when I had it apart I thought there could have been more presicion in the rod/crankpin, having had Novarossi's apart they are a much tighter fit you have to tease the rod off there, but this one it's almost like it had a bit of play already.
#1009
All ive got to say is Gene Hickerson and VpProUsa is absolutly awesome. Had little issue this weekend,But came back with my older Arrow finished 10th in Amain pretty good considering my problem. Talked to Gene, man that guy is awesome,took care of everything. These motors are great,Ive raced in 100 plus degree high humidity Georgia heat and now really cold damp nites, and they dont miss a beat! Just wanted to give the guys at VPPro and big thank you! Curt
#1011
I doubt that you'll find a pullstart. Maybe, but I doubt it. It is also considered a big block, so it won't fit the stock mount.
#1012
Hi all,
Just purchased this engine myself still waiting for it to come in the mail and was wondering what pipe you guys can recommend.
So far reading the thread I'm under the assumption that;
2035 for all round power and good runtime
RE11 for good bottom and top end
2060 and re11 the same?
2072?
Could anyone else recommend a pipe? I'm after heaps of bottom end good mid and high plus 10min or more runtime.
I'm running this engine with a 14t and m2c 4 shoe clutch.
2072?
#1013
We have try many pipe but no success. The OS 2060 deem best for this engine.......getting it super efficient in run time and consistent engine performance with no mysterious flame out.
Set the clutch 1.0 X 4 on your clutch......run 7/7.5 mm venturi and you will get about 10 mins minimum runtime.......
Tuning is easy but watch the mid speed need as mentioned by Gene in previous posting.
If you ignore that, the engine will run super erratic with idling speed going high and unable to drop back to idle speed after couple of rounds.
#1014
Hi,
Thanks for the reply. That pipe though 2060 is a little expensive. Is there any other alternative besides the 2060? Could someone please comment on the pipes i mentioned.
"2035 for all round power and good runtime
2072?"
2072?"
#1015
2035 doesn't sing in tune, re11 is older OS 2050.......both pipe....not compatible with this engine......
OS 2060 is expensive, option would be a used one more viable. as OS pipe is super hard and not possible to destroy one.....thats explain the price...and its quality.
Performance with it......silky smooth, very easy to drive and that help with the runtime.......tuning window bigger and ease of tuning.
#1016
#1017
Thanks for the info guys. After reading at least 15+ pages of this thread I think the best choice is the 2060 pipe. Picked one up for 147usd off eBay. And couldn't be happier I spent the extra cash for a quality pipe. Now I'm extra eager to get it/test it.
#1018
Well, I've broke two crankcases in as many months. The first one was in my truggy and the rod decided to leave the crank at top speed going down the strait. Not the sound you want to hear. 30,000 rpm to 0 in a millisecond. The rod punched a hole in the case.
Now, just this evening, I was replacing the rear bearing and con-rod in my buggy Arrow and pulled the bearing and was cleaning the case and what do you think I found...
A crack on the inside running along the motor mount. You have to zoom in to see it.
Now I'm down to one Arrow left that's in my truggy that replaced the thrown rod motor and it was involved in a wot run away with less than a gallon on it. Needless I could and did remove the break-in shim after that
I think I'm gonna try to repair it, weld the outside and grind smooth. I'll see if it will hold up. I like these engines, I bought three before they were available to the general public from Jaz240.
I guess I'll have to throw my backup motor till I get this worked out.
Cheers
Brian
Cheers
Brian
#1020
Not there isn't any other pipe out there. But once you hook yourself to a OS 2060, you never look another pipe again for it's performance, durability and quality.........
