Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 10-12-2012 | 11:52 AM
  #991
Originally Posted by VPProUSA
Heading to the track in the morning to break in my V3.
I took the carb apart and looked at all the neddles. I am starting with this:
Idle gap - .6mm
High - 2.5 out
Low - 1 turn in at noon
Mid - 2 turn out from flush at 2 o'clock
That looks like the best settings to me. I will report my results Mon.
please post what altitude,humidity and temp also
xray808-11 is offline
Old 10-14-2012 | 04:55 PM
  #992
VPProUSA's Avatar
Got to B&B at noon of Fri. Used heat gun to cycle engine to 250'F. Let cool down. Heated again to 250' and started with VP Racing break in fuel. Used Thunder Innovation heater and idled 1 tank. Kept temp at 200'F. Let cool. Repeated 2nd tank. Let cool. Heated again and started. Blimped throttle on and off entire tank with TI heater still on. Let cool. Heated again. Started and richened high needle 1 turn, opened full throttle so wheels were spinning slowly while I held a heat gun to block to keep it at 190'+ for entire tank. Let cool. Heated and started again and drove in street 1 tank with VP 25% fuel and put on race tune. Let cool. Heated 1 more time and put it on the track. Fine tuned each tank with no heat gun needed. Ended with these settings:
Idle .7mm
Mid range 2 turns out from flush at 2 o'clock
Low 1 turn in from flush at 2 o'clock
High 1 and 3/4 out from all the way in
7mm reducer
Temp 265'f
Humid, mid 80's
2060 pipe
P3 plug
Engine ran perfect and had almost half a tank after 5 min quals. Never flamed once and idled like a kitten.
VPProUSA is offline
Old 10-14-2012 | 04:58 PM
  #993
VPProUSA's Avatar
Also I did not use the break in shim. Temp was about 280 for the first 4 tanks on the track, then it broke in and cooled to 240, so I leaned it out more.
VPProUSA is offline
Old 10-17-2012 | 12:05 AM
  #994
brooklynny's Avatar
Can you run this engine in a truggy?
brooklynny is offline
Old 10-20-2012 | 12:32 PM
  #995
ive been running this engine in both buggy and truggy for a year now with great success
gofast072 is offline
Old 10-20-2012 | 04:21 PM
  #996
brooklynny's Avatar
Thanks, how about matching pipe for a truggy
Old 10-20-2012 | 08:38 PM
  #997
i use a werks 2013 on both
Old 10-22-2012 | 08:33 PM
  #998
Stock factory carb settings?
60_cent is offline
Old 10-23-2012 | 05:59 AM
  #999
VPProUSA's Avatar
Idle .7mm
7mm reducer
Temp 265'f
Humid, mid 80's
2060 pipe
P3 plug
Use these carb settings. The factory settings do not work.
VPProUSA is offline
Old 10-23-2012 | 09:28 AM
  #1000
Danny Teh's Avatar
Agree.....
Danny Teh is offline
Old 10-23-2012 | 11:03 AM
  #1001
I will try it out...
thanks
60_cent is offline
Old 10-23-2012 | 04:40 PM
  #1002
VPProUSA's Avatar
thanks
I set everyones arrow carbs at the track last weekend the same as mine and they all loved it.
VPProUSA is offline
Old 10-26-2012 | 03:37 AM
  #1003
Danny Teh's Avatar
the setting is almost identical in every engine.....consistent, ease of tuning and reliability.
Old 11-02-2012 | 05:28 AM
  #1004
Got my new Arrow engine in yesterday, looks good, although this thing is SUPER tight, couldn't even really turn it over by hand with the flywheel on, are they all like this? Guess once I start the break in and heat up the head it will be easier to turn over and start? Lookin forward to see how she runs!
dirtbikekid2 is offline
Old 11-02-2012 | 05:35 AM
  #1005
CKmaxx's Avatar
Why would you try to turn it over by hand?? Every new engine is like this. Keep the engine out of the pinch zone until you are ready to start it. Heat it to 200 degrees before attempting to start....
CKmaxx is offline
