Argus USA Engines Thread
#437
I dont know about the JP4 but I do know the ones that I have tried, and as of right now the 2057 has been the best for a smooth bottom and a screaming top. All around best pipe I have used and still using is the 801. Also the 2035 and the 2013 work really well also. These have all been tested in a truggy.....
#438
To me the 2057 takes too much away from the bottom in truggy, Buggy its ok. 20801 or f 0801 seem to be best all around to me. BUt i like a lot of bottom end. With e 0801 pipes they are kinda the whole package. The 2013 does work decent though like you said. Thats the great thing about this hobby. so many options!!!...lol
Lance
RcRenew
Lance
RcRenew
#439
Lance
RcRenew
Lance
RcRenew
#442
Pipes were supposed to be here last week, but havent arrived yet. We should have them in next week. we are going to start carrying the 2081 instead of the f0801. They put out more power on the lower to mid rpm and have the same xlnt fuel economy. So I think we are going to stick with that pipe.
Thanks,
Lance
RcRenew.com
Thanks,
Lance
RcRenew.com
#444
I will start breaking in my new argus.
1) I usually run a OS P4 plug. Will it be ok to break in with that plug? A P3 would be better?
2) Since I could not see any instructions in the package, there is an extra head sim included - should I use for break-in? And if yes, for how long? Entire break-in?
Thank you,
Vagelis
Thank you,
Vagelis
#445
Got the final break in done on my Argus and I must say it seems to rip. Rex did 2 tanks, on the break in bench, I did 2 tanks on the box, then 2 tanks on the track at the Sandbox Arena in New Richmond, WI. After that, leaned the top about 2 hours and she is humming allong nicely.
Running the 801 pipe and a O'donnell 87T plug and it has a great amount of mid-range and is very linear. I had some concern about how the powerband would be in a light buggy (JQ car) and it seems to be very smooth.
Definatly looking forward to some track time.
#446
#449
Thank you,
Vagelis
Thank you,
Vagelis
The P4 will be fine, But we mostly use the P3 plugs. The P3 plug will be better for break in as well.
And yes, install the extra shim for about 10-15 tanks then remove it. The rcpro plugs and werks plugs seem to last a lot longer than the OS plugs. The #5 is like a OS P3 and the #6 are like the OS P4
Thanks,
Lance
RcRenew.com
#450
Started beaking-in with heat cycle method...
wow....
even though I am not experienced in break-in (my 4th engine...), I can say that it is very very easy to get the engine started and running in the appropiate temp!!!! Just preheat the engine and go!!!!
Thank you,
Vagelis
wow....
Thank you,
Vagelis
1Likes
