Like Tree1Likes
Argus USA Engines Thread
Old 03-29-2016 | 08:36 PM
  #2056
invrtd's Avatar
Which would you recommend, a modified A5 or R83 for GT?
invrtd is offline
Old 03-30-2016 | 04:16 PM
  #2057
22Racer's Avatar
Both would be very good, the R83 has a lower head and looks nicer.
Rex
22Racer is offline
Old 03-31-2016 | 04:13 AM
  #2058
UrabusDenis's Avatar
I'll be doing some pipe&manifold testing in the following days with my new modified A5 (in GT), I'll drop the results here
UrabusDenis is offline
Old 04-22-2016 | 03:34 PM
  #2059
Default R83
Just wanted to pop in and give an update. Long story short i am a high level racer who took some time off, when planning my return i reached out to Rex at rw-mods because he had helped me in the past. After speeking to him i ordered an Argus R83 and he lapped it in for me also. I decided to try a whole new breakin procedure and that went quick and worked well. So it was time to hit the track! I completed my breakin and got it tuned in quickly. So what did I think? This motor screams!! I am running it in my truggy with 0801 pipe. Some guys say they want a truggy to have real strong bottom and top matters less but i am the opposite. With buggy i charge hard into corner, get hard on brakes and hit the inside line and accelerate hard out of corner. However with truggy i tend to really hang it out and dont worry about inside line and tend to drift alot more because flipping over in ruts is much less likely. So with truck I maintain more overall speed accelerating less so i look for an engine with unlimited top end that never signs off. Well this R83 engine fits me perfectly it has plenty of bottom for my style and rips in mid and top. I have never ran an engine that pulled so long and never stopped pulling i am super happy with it. I look forward to racing this engine very soon. Thank you Rex👍
adubaz7 is offline
Old 04-22-2016 | 07:08 PM
  #2060
invrtd's Avatar
I haven't tried the R83 yet, but I can say the R8 is a awesome motor too. I run a spec R8 in buggy, and a modified one in Truggy. I have put my modified one in my buggy a few times, and in buggy, its super powerful. The modified R8 in truggy is a stump puller with great top end too. Customer service and pricing with Rex is Awesome. My R8 keeps up with some other modified's that cost double the price. And for you guys on the fence about Argus, look at how successful Ryan Lutz has been with Alpha. These are rebranded Alpha's like Novarossi Top and REX.
invrtd is offline
Old 05-26-2016 | 08:44 PM
  #2061
invrtd's Avatar
Any updates on the GT motor?
invrtd is offline
Old 05-27-2016 | 12:03 AM
  #2062
Yes, I've had my first international race with the Argus A5 GT last weekend. The engine pretty much outran almost all of the competition (R5 GT, Mito GT, Ison GT, ...), the top end is simply huge. I managed to put the fastest lap of the qualifying and finished 3rd in the final after a long fight against great competition. Trust me, the engine is unbelieavable
After a lot of pipe&header testing I decided to use an Alpha 2107 pipe with the long round Argus header (the one which you get in the Argus 2090 pipe combo). I will continue pipe testing but this works pretty good everywhere. Plug wise, I am using a Picco P7TH although the O'Donnell 299T also gave good results as well. I have some Novarossi C8TGHs to test next.
Old 06-22-2016 | 05:07 AM
  #2063
invrtd's Avatar
How's the pipe testing going? What would you compare the 2017 too. A high speed, mid range, or bottom end pipe?
invrtd is offline
Old 06-24-2016 | 04:29 AM
  #2064
In my opinion, the 2107 has more power than a 2090. In buggy, I'm undecided on 2090 vs. 2107 so I use both on different occasions but in my GT the 2107 is better. That being said, the header is the biggest difference, I've tried lots of them, from the short Nova 41032 (reccomended for their GT) to the long Argus header which works best (by far). The engine has huge top end, and the long header gives the much needed torque since the cars are so heavy. I've tried other pipes and manifolds, from different brands, nothing comes close to this combo with the RW modded A5 GT. Gearing is also very important in GT, so is track size.
Old 06-28-2016 | 07:05 AM
  #2065
sqamtech's Avatar
The new ARGUS K3
sqamtech is offline
Old 06-28-2016 | 08:49 AM
  #2066
invrtd's Avatar
Probably a Dragon III re branded? And I am fine with that. Just another motor to have an option to run.
invrtd is offline
Old 06-28-2016 | 10:59 AM
  #2067
same specs...I have had great luck with my Dragon so you guys will probably like them
Specifications for the Dragon from LutzRC:
Displacement: 3.49cc
Bore: 16.26mm
Stroke: 16.8mm
Practical RPM: 4,000 - 40,300rpm
Power Output: 2.80PS/38,800rpm
Weight Approx: approx. 361g
Ports: 3 Ports
Sleeve: ABC
Crankshaft: Dynamic Equilibrium Crankshaft w/Special Material
Crankshaft Diameter: 14mm
Glow Plug Type: Turbo
Exhaust: Rear
Carburetor Diameter: 8.8mm (Variable)
Case Material: Aluminum
Carburetor: 3 Needles
Bob Barry is offline
Old 07-12-2016 | 10:25 PM
  #2068
invrtd's Avatar
Rex, are you going to get any R8's in stock. Been talking with others about GT and 2 folks have said a plus 2 is OK. MES are not considered ports. I had this discussion with ROAR myself and they said no MES but other folks are saying otherwise. I think ROAR is misinformed and ignorant at times. The R8 would be a better motor in my opinion for GT with additional ports and higher timing.
invrtd is offline
Old 07-13-2016 | 03:21 AM
  #2069
They are considered illegal by both ROAR and EFRA (had this confirmed by the 1/8th track chairman, for the R8/Alpha Lutz specifically). Only true 5 ports are allowed, which is the A5. I do agree clarification is needed, however their word is the final word. Surely you don't want to get an engine which is illegal at the ROAR races
Old 07-13-2016 | 02:02 PM
  #2070
22Racer's Avatar
It is no problem as the A5 modified can make just as much power as the R8. I am testing a R83 3 port with a mod for truggy this weekend.
Rex
22Racer is offline
