Like Tree1Likes
Argus USA Engines Thread
Old 07-15-2016 | 03:18 AM
  #2071
invrtd's Avatar
It's interesting you say the R8 is illegal. I have gotten conflicting information. MES ports are not counted as ports is what I have been told by some. Several of the GT legal motors are 5+2's so are MES Ports legal or not. Last time I talked with ROAR, almost 2 years ago, I couldn't get a straight answer. It's frustrating. Example below of description of PICCO GT motor. It has MES ports just like R8.
Torque .21 EMX-GT Cer highlights
• 5 ports + 2 bypass hard chromed liner
• CNC machined billet piston
• Balanced 14mm turbo cranckshaft with silicone insert
• Super aligned "Knife edged" aerodynamic connecting rod
• Separate large size turbo combustion chamber insert
• 14mm ceramic Swiss quality main bearing
• Bigger super lightweight cooling head
• Composite slide carburetor
• 7.0mm and 9.0mm venturi inserts
invrtd is offline
Old 10-20-2016 | 02:35 AM
  #2072
Default R8 head shims
Hi guys, I just got a R8 with the Tb1 pipe. Was wondering if anyone could let me know break in needle settings and was wondering if the extra shim in the box is for break in ? At the moment its got 3 0.2mm shims from factory.
shotcrank is offline
Old 10-24-2016 | 02:02 PM
  #2073
22Racer's Avatar
I usually run the engines in at about flush or slightly in from flush on the hsn. The Lsn about 1mm out from flush. Head shimming should be 2x .2mm and one .1mm.
When you are ready to tune it the idle gap should be .7mm, lsn about .5-1mm out and in from flush on the hsn.
Rex
22Racer is offline
Old 10-24-2016 | 05:09 PM
  #2074
cczjordan's Avatar
Recently i bought argus R8 crankshaft to replace my worn nova 4btt crankshaft, what can i expect from this crank?
cczjordan is offline
Old 10-25-2016 | 04:35 AM
  #2075
rider313's Avatar
what made you believe the R8 was a fit in the nova Btt?
rider313 is offline
Old 10-25-2016 | 06:47 AM
  #2076
cczjordan's Avatar
Confirm it will fit, just no sure bout the timings n portings
Old 10-27-2016 | 04:27 PM
  #2077
22Racer's Avatar
I think the timing would be close but there is no way of knowing without measuring it up and checking timing.
Rex
22Racer is offline
Old 10-27-2016 | 09:28 PM
  #2078
cczjordan's Avatar
Rex
Thanks rex, i do track testing n feedback.
Old 10-30-2016 | 04:31 AM
  #2079
cczjordan's Avatar
Rex
It is an upgrade for 15007T crank, can try it if handy
Old 02-09-2021 | 03:42 PM
  #2080
Hi anyone out there still running Argus?
the price to performance ratio is pretty awesome.
I just sold my sh engine and am looking at some budget engines.
I found the A5 and the B52 is within my price range.
A5 in the buggy and B52 in Truggy is a good idea?
Thanks.
Exiger is offline
Old 02-10-2021 | 11:50 PM
  #2081
Thanks.
i see rw mods just got some to review them
jersey is offline
Old 02-14-2021 | 08:45 PM
  #2082
thecman26's Avatar
R/C Tech Elite Member
available for purchase as well on his pre-order. Pretty cheap too!
thecman26 is offline
Old 07-01-2021 | 08:28 PM
  #2083
Sixes's Avatar
RIP Rex. I’ve learned so much from his vids and input in the threads.
Sixes is offline
Old 07-01-2021 | 08:35 PM
  #2084
Sixes's Avatar
Looking to get a new connecting rod for my Argus K3 but the part number #AG21-MO51 isn’t available to me locally, so wondering if the R8 connecting rod would work #AG21-M0062 in the k3 or are they different length?
Sixes is offline
Old 07-01-2021 | 11:14 PM
  #2085
i think it’s the same engine as alpha dragon 3. Get parts from lutz Rc. D4 rod might fit to I heard but not sure.
Rw mod did review on k3 and said it was same as d3 like I thought. I remember dragon 2 people said you could use a d3 rod on it it was just revised to be stronger or something if I remember right someone telling me that.
but yea see if lutzrc has alpha dragon 3 rod. If not the 4 might fit but not sure.
Video Rex saying dragon 3 same as k3
https://www.lutzrc.com/product-page/...d-21-dragon-iv
Lutz has dragon 4 rod it might fit but not sure maybe send lutz a message
jersey is offline
