Like Tree1Likes
Argus USA Engines Thread
Old 03-13-2015 | 02:14 PM
  #1906
22Racer's Avatar
Originally Posted by kostas xray
hello my engine is argus a5 it has only 5 litres or 1.5 gallon if you prefer this inludes the break in.but only 1 litre is on track all the rest was used in break in.i open the engine to clean it and the rear bearing is bad too loose .if i grap the flywhell i can move it right and left .the engine work great no flame out no overheating.i use hot fire (kyosho) 25% nitro fuel.my lhs told me the reason is the fuel so i order new bearing and a 25% meccafuel.what do you think about this failure of the rear bearing??
If the crank moves in and out with the flywheel on the front bearing is bad.(small bearing)
Rex
22Racer is offline
Old 03-13-2015 | 03:20 PM
  #1907
I doubt it the fuel. If you lost the front bearing from what it sound like. Did you have a shim behind the collet to space the collet away from the bearing. Did the shim only thouch the inner race of the bearing. My argus engines have over 5 gallons and still all on the stock bearings and internals..
imrob is offline
Old 03-13-2015 | 03:51 PM
  #1908
thanks for the reply.it does not move in and out but right to left side side.i remove both bearings front feels right but rear not.in the rear bearing i can move the inner race in and out too much.no i did not place any shim ibehind the collet the collet touches only the inner race of the front bearing and when i grab the flywheel i can not move it in and out but only side to side.i can not change bearings every time i go to the track so something i do wrong but what?
kostas xray is offline
Old 03-13-2015 | 03:59 PM
  #1909
thanks for the reply.it does not move in and out but right to left side side.i remove both bearings front feels right but rear not.in the rear bearing i can move the inner race in and out too much.no i did not place any washer in the flywheel collet the collet touches only the ineer racer of the front bearing and when i grab the flywheel ican not move it in and out but only side to side.i can not change bearings every time i go to the track so something i do wrong but what?
You could have just got a bad bearing. But also did you run it really rich for the first gallon or at least doing break in. Also you might try Bryons caster oil additive amain hobbies sell it i use it for break in only. After that I use marvels mystery oil when the sit for the winter. When you put in the new bearings it would be a good Idea to oil them before you close the engine up. If you don't have the hudy bearing tool buy it trust me best tool on the market for installation of bearings and taking them out... I also when I have to break in the engine is open them up and drop some oil on the rear bearings too. Hope this help.
imrob is offline
Old 03-13-2015 | 04:20 PM
  #1910
i was very gentle with break in i put a few drops of oil before even starting for the first time preheat it for the first gallon always.and for the first half gallon i use 16% nitro fuel.always monitoring the temp.and after every use i burn all the remain fuel until engine dies and the i use wd40 as after run oil.only for two tanks at the track i was lean on lsn
Old 03-13-2015 | 05:12 PM
  #1911
I would stop using wd40 for after run oil. It not an oil substance and does have a flash point of 300 degrees. It will clean out what ever oil is in those bearings. I know Traxxas say spay wd40 into the carb to clean it out but after ward they also state put after run oil in the carb. That could be your problem there.
imrob is offline
Old 03-14-2015 | 01:39 AM
  #1912
ok thanks.but i like wd40 because when i open the engine it was very clean inside.how about use wd40 after my last run to clear the engine and then some oil??is this better?
Old 03-14-2015 | 10:17 AM
  #1913
I would think that would be better but not best. You should see a yellow film on you engine internals that is the oil from the fuel protecting the engine. Wd 40 will clean it off everytime.
imrob is offline
Old 03-15-2015 | 12:28 AM
  #1914
cczjordan's Avatar
Some fully synthetic fuel will make the internal look clean but i prefer fuel with castor/synthetic, it will left some oil after each run, good to prevent dry start n rust building up
cczjordan is offline
Old 03-20-2015 | 08:46 PM
  #1915
invrtd's Avatar
I am going by the track this weekend to finish breaking in a motor. Got a few tank fulls on it last weekend, but she is still tight. I am hoping the motor drops it's nuts tomorrow. So far, the motor hasn't missed a beat even though it is tight.
invrtd is offline
Old 03-24-2015 | 11:16 AM
  #1916
Pit-racer's Avatar
Originally Posted by invrtd
I agree with that bypass ports shouldn't be considered ports. I will do some more inquiring about that with our race director. If I could just get a good view of a novarossi ISON GT piston and sleeve on the web I could count the ports. It's supposed to be a roar compliant motor but says 7 ports on the novarossi site. Picco also make a roar legal 5 port and will see if I can find some pictures of it. I was really looking for the R8 for GT but I know it will raise alot of flags if someone see's an 8 on the case and will think it's an 8 port. I just wish we weren't going to roar regs and wouldn't have to worry about it.
Yes the RW Modded R8 works really well in GT8. I ran this engine in 2014 in Texas SWCS and local smaller tracks. At first everyone said "What engine" and it kept up with everything out there. Yea I have to go 5port everywhere I race now. Darn!
Pit-racer is offline
Old 03-24-2015 | 09:25 PM
  #1917
22Racer's Avatar
The A5 is 5 port with no bypass, I can put it in the R8 you have also.
Rex
22Racer is offline
Old 03-24-2015 | 09:26 PM
  #1918
22Racer's Avatar
Coming soon!!
22Racer is offline
Old 03-25-2015 | 04:35 AM
  #1919
UrabusDenis's Avatar
3-port racing engine? Very excited
UrabusDenis is offline
Old 03-25-2015 | 07:35 AM
  #1920
invrtd's Avatar
How's the power band on the new 3 port? Is it going to be a better buggy or truggy motor. If it has good bottom end, it would be great in a GT too. The picco and nova approved GT 5 port motors have bypass ports. They are 5+2. I am going to run my R8 in my GT at the track in LA. Still waiting for roar to update info on the roar Web page about rules on 5 port motor. Specifically about 5+2.
invrtd is offline
