Modd head button
Old 11-14-2010 | 08:25 AM
  #46
rider313's Avatar
Thanks neal for doing this test with your dyno. You saved alot of guys head buttons. lol Not every engine guy out there would do this test and post there results. A+ work.
rider313 is offline
Old 11-14-2010 | 12:05 PM
  #47
houston's Avatar
Originally Posted by Maximo
I was disappointed to see it lose power, I was hoping to find a new little trick to add a little more power...But the power drop was very apparent, I made multiple passes on the dyno and tried retuning the engine to see if the tune had changed...but no matter what I did the power was down...only after I raised the compression did the power recover some...but I think with the raised compression and the normal button power would have been even better......On my modified B5 this mod hurt power, there is no question...maybe on another engine the results would be different IDK.... Sorry to disappoint you guys, I tried my best to make it work !
Did u try different configurations? From personal experience , smaller more directing grooves yielded the most gain . One exiting towards the exhaust
houston is offline
Old 11-14-2010 | 12:15 PM
  #48
wingracer's Avatar
I think that IF it can work, it would work better with a very narrow cut, like from a razor saw rather than a big channel but that requires more testing and more heads
wingracer is offline
Old 11-14-2010 | 12:49 PM
  #49
Roelof's Avatar
Worldwide results with bigger engines do no lie, maybe the results on our engines are more related to compression because that is making the ignition timing? I know most onroad engines do come with a very critical compression setting, almost to detonation but it does not comply with my friends 23cc engine with spark ignition.
But then I am wondering how the large teardrop I have seen through the years and even made in the RB C5 production models is actually working on the dyno.
Roelof is offline
Old 11-14-2010 | 01:06 PM
  #50
Maximo's Avatar
2 towards the front, 1 towards the exhaust.....
I have tested these cuts before and found no benefits, but i did not have the dyno at the time to properly know for sure... Back when XRC did a dyno test of this technique it got my interest...... Now it may be possible that some configurations may work on some engines..But unfortunately the cost to do the testing would be quite significant...But the configuration I tried on this B5 hurt power, so I likely wont be pursuing this any further.....I will be testing a Rody modded button against a standard button very soon, so I will let you guys know what I find.......
I have been modifying head buttons for some time now, but I am more into messing with squish velocity then anything else...
Maximo is offline
Old 11-15-2010 | 04:27 PM
  #51
Thanks for the testing. I was looking for better results but what do you do.
dayglo33 is offline
