Modd head button
Old 10-23-2010 | 07:25 AM
  #16
sluggo_sx8's Avatar
Originally Posted by wingracer
http://somender-singh.com/content/view/68/49/
Most of these are real car and go kart heads but there are a few of a single groove RC head.
coool thanks
sluggo_sx8 is offline
Old 10-23-2010 | 08:48 AM
  #17
Roelof's Avatar
Like this (original -> modded)
Roelof is online now
Old 10-23-2010 | 09:02 AM
  #18
Maximo's Avatar
I will do some testing today, and post my results back this evening....Should be pretty interesting !
Maximo is offline
Old 10-23-2010 | 09:08 AM
  #19
jpalessi's Avatar
I would think you'd have to readjust the head.
jpalessi is offline
Old 10-23-2010 | 09:19 AM
  #20
Roelof's Avatar
If you do the 3-groove mod, maybe also an idea to rotate the button head 180 degrees to see if it has some influence.
Old 10-23-2010 | 10:20 AM
  #21
houston's Avatar
I've seen it done , I've played with it , it definitely works but needs to be scaled down to our engine size.
Fyi , it works better done just inside the actual combustion chamber part of the head button
Reason its not widely used in our engines (micromotor nitro) is it has an inconsistant power delivery and odd power band transfers .
Pluses are increased fuel and max rpm gains along woth cooler running temps
houston is offline
Old 10-23-2010 | 11:59 AM
  #22
Houston, when you say inconsistant power delivery, are you saying the motor flames out alot or stumbles at low rpm sometimes or what? How many cuts did you use? How deep were the cuts? Were the run times noticly better? How much cooler? Any input is very apperciated.
dayglo33 is offline
Old 10-23-2010 | 12:15 PM
  #23
houston's Avatar
i am talking fluctuations in power delivery , like spikes in certain rpm and dips in other
runtimes on average were probably 20% better , temps i would say about 15-25% cooler ( depended on engine design ) , tried several three cut methods and the one that had the most consistency and gains in all areas was the .25mm deep cuts inside the combustion chamber of the head button in counter clckwise fashion (pics needed to explain fully
houston is offline
Old 10-23-2010 | 12:30 PM
  #24
jbright33's Avatar
interesting
jbright33 is offline
Old 10-23-2010 | 01:08 PM
  #25
Now you know i'm going to ask for a picture! Are you saying that you put the cuts closer to the glow plug when you say you put the cuts in the combustion chamber? Are they angled then too?
The spikes and drops were on a dyno I take it? Did you run the motor in a truggy or buggy?
dayglo33 is offline
Old 10-24-2010 | 05:39 PM
  #26
jbright33's Avatar
hmm what happend i was watching this thread was very interested in it. neal did you do any testing?
Old 10-26-2010 | 11:04 AM
  #27
Roelof's Avatar
Did you manage to do some testing?
Old 10-26-2010 | 11:36 AM
  #28
Maximo's Avatar
I am going to right away...I had to put together a dyno mule to test with...Alll I had broken in and ready to roll were some pricey engines ...So I didn't want to experiment with anything too expensive
Maximo is offline
Old 10-26-2010 | 06:10 PM
  #29
rotarynut's Avatar
Wink Somender Singh
For those of you that want to do some reading into this subject, it explains what it does and how it's acomplished. Very interesting...seems that he got he ROYAL blow off from the big companies,why?...'cause they didn't think of it first.
http://www.rexresearch.com/singh/singh.htm
rotarynut is offline
Old 10-26-2010 | 08:05 PM
  #30
houston's Avatar
that was a good half hour of reading , although a few sections were just reiterations of previous sections there was some great info and i feel inspired to do a little more testing
houston is offline
