PICCO .21 BOOST
#76
Sounds good, Sam that was quick postage was a little skeptical about getting one form there have heard a few bad reports but never purchased from there... Im very keen for a change of engine at the moment.....
#77
That screw is to close to the flywheel and could be a problem when you want to adjust the idle during a race and hit the flywheel In an onroad the carb is 180 degrees rotated, some brands have mirrored the onroad carb so it will have a better place in an offroad.
#78
Never had an issue with rc mushroom, 3-4 days max and things arrive, have purchased there at least 6 times with out issue and fast postage....
I have never had an issue with the idle screw where it is placed, i run a jammin/picco jpx 21, jammin/picco jpx 21 plus, jammin/picco jpx 28 & the picco 21 boost is the same placement, i find it easy to get to when just lifting the side ofthe body up on race days...
#81
#84
I used 4 x P5TH hot turbo plugs during a 84 litre life with my jammi/picco 21
#85
Cheers sam will get onto the Picco plugs then, I had heard that OS plugs work but just wanted to make sure before i put one in and maybe damaged the seal up on the boost from the plug being wrong.
#86
Shimmed sleeve allows to adjust timing of motor for different driving styles.
#87
Well today i installed the picco 21 boost engine into my hot bodies D8t truggy and started the break in of the new engine & pipe combo, Here is some pictures and video footage of the first start up to do the 1/2 tank of heat cycling and then the 1st drive for 1/2 tank at 1/4 throttle, ENJOY
Sorry about the video quality it was dusk and the camera auto focus was having a hard time...
| + YouTube Video | |
#88
| + YouTube Video | |
#90
