PICCO .21 BOOST
Old 12-12-2010 | 01:56 PM
  #196
MassiveMods's Avatar
Originally Posted by blade954
Hey mark, Well when i asked you again delivered we were happy with the Boost the engine had every thing from bottom to top and so smooth and crisp. Jaicob loved it... And we still had great run time.....
Now thats what i call massive modding ! cheers
MassiveMods is offline
Old 12-12-2010 | 08:09 PM
  #197
camiloro's Avatar
this is a top end or botton end engine, i found much botton end
camiloro is offline
Old 12-13-2010 | 10:36 AM
  #198
drpower's Avatar
Default Choices
Hello guys, great forum! After much reading its obvious you guys are pro at this. I want to repower my 9.5 MBX with some quality power and with my limited knowledge have a few engines in mind. The Boost is an amazing $199 complete with a pipe and header so its almost top of my list. So here goes:
Picco Boost set $199
Novarossi Plus 21-5 $250 - ?pipe?
O.S. 21VZ-B V-Spec #13895 $240
T-2050 Tuned Pipe $140 }almost $400! I could buy two boosts!
any other suggestions would be great, thanks
drpower is offline
Old 01-17-2011 | 03:29 PM
  #199
lucasand's Avatar
Hello guys, I´m new here, my name is lucas, and i´m from brazil.
I really want to buy a agama A8 and here is the only where i find informations about the car becouse in brazil none has this car yet, i think i will be the first one ...
I have already bought this picco boost engine, and i was searching which glow plug i should use, and i saw that u guys are using turbo plugs, but at OFNA´s web site they say that the picco boost uses standard plugs....
have a look here: ofna.com/picco-boost.php
so, are they wrong?!?
Thanks.
Lucas.
lucasand is offline
Old 02-10-2011 | 09:58 AM
  #200
STUBYSLAP31's Avatar
R/C Tech Elite Member
HEY GUYS, WELL LONG STORY SHORT, I LOST MY JOB LAST YEAR, IM JUST NOW GETTING BACK TO RACING, IVE ALWAYS BEEN A OS SPEED GUY, IM NEEDING A NEW LOWER PRICE ENGINE PIPE COMBO FOR THE FIRST 2-3 MONTHS OF RACING
IM LOOKING AT THE
PICCO BOOST
GO GX-5R
WERKS B5
DO YOU GUYS HAVE ANY INCITE ON HOW THESE COMPARE
STUBYSLAP31 is offline
Old 02-10-2011 | 12:13 PM
  #201
IM LOOKING AT THE
PICCO BOOST
GO GX-5R
WERKS B5
Picco Boost is good, 2 gallons and running very strong. I really like the bottom punch, lacks a little top end but nothing major. Good fuel Mileage.
Before that I had bought a Werks B5. W/ 1/2 gallon through it, nothing but problems. Couldn't idle and phantom flame outs. Just don't tell Ron I said that. I was really looking forward to the B5 but you can't run something that won't stay on.
arm2storm is offline
Old 02-10-2011 | 12:34 PM
  #202
Thanks, keep the info comming
Old 02-10-2011 | 12:48 PM
  #203
Lol, I hear ya on that! Good thing that the couple thousand B5's that are floating around in other peoples hands don't have that issue All joking aside if you still have the engine and need some help PM me your # and I'll give you a call to work through the tuning. It's really basic with these engines but if you get out of whack as with any motor it can get a little confusing.
Ron
Werks is offline
Old 02-10-2011 | 03:22 PM
  #204
Ron
I don't think the tuning on a B5 should be much different from any other .21 engine, but Let me dig it out and mount it on my buggy, once I get that going I'll pm you my #.
Old 02-10-2011 | 04:53 PM
  #205
t8rtot's Avatar
I have a friend running a boost, he switched to the picco 2072 pipe and said the motor really came alive, with plenty of mid-top speed
t8rtot is offline
Old 02-10-2011 | 05:14 PM
  #206
Your right, it should not be any different than any other engine which is why if you are having problems then either your needle settings are way off or there is something else wrong with the engine, fuel tank or what have you. In any case this is the Picco thread so lets get it back on track. If you try out the engine again and have any issues drop me a line and I'll do my best to work through them with you.
Regards,
Ron
Werks is offline
Old 02-16-2011 | 08:03 AM
  #207
camiloro's Avatar
Good day, i need information about the break-in engine, a manual, article, etc.
thanks for the help.....
camiloro is offline
Old 02-19-2011 | 10:17 AM
  #208
camiloro's Avatar
hello............the home is alone???????
who have the manual to break in??
camiloro is offline
Old 02-20-2011 | 01:45 AM
  #209
blade954's Avatar
I found the boost needed around 8 tanks to loose the mechanical pinch and to develop a nice pop when turning the flywheel. Give the Boost 4-5 tanks rich then start to lean the top out when happy with it work on the bottom, I found the Boost likes a slightly rich bottom end and a leaner top end....... The Original Picco 2046 chokes the Boost i found the Go Tech 2072 really woke the Boost up....
blade954 is offline
Old 03-27-2011 | 07:18 PM
  #210
Marcus Falconie's Avatar
So what kind of fuel Mi are you all getting with this engine?? Thanks
Marcus Falconie is offline
