Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-27-2016 | 01:52 PM
  #9106
bash bros's Avatar
Originally Posted by qstorm777
So how do I tell the difference in a long needle and short needle carb if looking down into the carb? Everything I read described what I was seeing with the 24063 carb as a short needle. Maybe I should have actually looked the needle up to see...smh.
24063 is definitely a long needle, pretty much the same as the 24069 that's on the p5, 4btt, bonito, etc... except for some very minor differences in the carb body itself
It's easy to tell because even with a 8mm insert the needle is not quite fully out of the spray bar.
Even though long needles can be trickier to tune it's also what makes them so smooth from top to bottom and less likely to have a rich spot in the mid range like a short needle.
bash bros is offline
Old 07-27-2016 | 03:22 PM
  #9107
Yeah, I just looke at the 24063 again. Carb has to be almost fully open before needle pulls all the way out.
qstorm777 is offline
Old 07-28-2016 | 04:26 AM
  #9108
invrtd's Avatar
51019--Anyone familiar with this pipe.
invrtd is offline
Old 07-28-2016 | 04:29 AM
  #9109
cczjordan's Avatar
It is
cczjordan is offline
Old 07-28-2016 | 04:30 AM
  #9110
cczjordan's Avatar
9901?
Old 07-28-2016 | 02:32 PM
  #9111
bash bros's Avatar
I don't think it's a 9901, looks like it's just a basic 2 chamber non-SS pipe
Old 07-29-2016 | 04:08 AM
  #9112
invrtd's Avatar
Just got some info that the 51019 is not a great pipe. Looks like the 9886 but not the same.
invrtd is offline
Old 07-29-2016 | 03:29 PM
  #9113
teeforb's Avatar
teeforb is offline
Old 07-29-2016 | 03:44 PM
  #9114
Why did you post that in a novarossi engine thread?
rotor head33 is offline
Old 08-04-2016 | 07:57 PM
  #9115
1/8 IC Fan's Avatar
Is the only change for the P5XLT-16 only the new head? curious to know if there were perhaps any other small changes? Great motor, would gladly run another.
1/8 IC Fan is offline
Old 08-04-2016 | 08:57 PM
  #9116
bash bros's Avatar
Different backplate, 3 needle carb, and silicone filled crank with a little bit more timing than the last p5xlt. Same p/s and pretty much everything else.
Old 08-05-2016 | 06:53 AM
  #9117
1/8 IC Fan's Avatar
Thanks, that's good to know. I'm gonna have to give the new motor a shot, loved the old one!
Old 08-21-2016 | 10:55 AM
  #9118
Default Mito 4 or drake 5off
For buggy. Which would it be for you?
Mito 4 or drake 5off?
Reasons?
NoobRacer is offline
Old 08-21-2016 | 10:49 PM
  #9119
cczjordan's Avatar
Reasons?
Mito 4 i haven't tested but 4btt is good for buggy for small medium track. It lacks the top for a bigger track. 2096/41033 for 4btt
Old 08-22-2016 | 04:06 AM
  #9120
mblgjr's Avatar
Given the price point is virtually identical I'd go for the Clio5 as it gets the lowCG head & nicer cnc/domed piston vs traditional microcast.
mblgjr is offline
