Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-28-2015 | 01:11 PM
  #7786
Maximo's Avatar
Originally Posted by AllyITA
that sudden drop at 32000rpm from the 9901 seems a little odd.. why is that?
Its even worse on the 41021 manifold..... But basically whats happening is the engine hits a point where the power drops off so much as that it no longer can accelerate the flywheel mass, or at least the acceleration slows substantially..... If the engine hit a specific RPM and was unable to climb any further the graph would read zero... As what the graph is essentially showing is rate of acceleration over time..zero acceleration gives a zero reading.... On this particular engine the 9901 doesn't rev out too well.... however on some other engines it runs like a banshee on the top end.... so it is what it is, the 9901 isn't the best suited to this engine, its not bad, but there are better obviously
Maximo is offline
Old 05-28-2015 | 01:56 PM
  #7787
Lille-bror's Avatar
Sooo cool facts Neal. Thanks a lot
Lille-bror is offline
Old 05-28-2015 | 04:21 PM
  #7788
Originally Posted by Maximo
And here is another graph from the same engine comparing the 9901, 2096 and a RB 2097..
I have to say that's quite interesting, I'm glad you posted these.
Have you done any other pipes, like Alpha, or 2058, 2060/2090 os pipes, etcetera? would be interesting to see the numbers and curves.
Going by this curve the 9901 is a total dud! Explains why I like the 2096 better.
Eivind E is offline
Old 05-28-2015 | 07:37 PM
  #7789
sn47som1's Avatar
So the green is the rb 2097 at the peak power point? If so, how would the 9886 fare against this?
sn47som1 is offline
Old 05-28-2015 | 07:51 PM
  #7790
sn47som1's Avatar
Originally Posted by Jerm13
I guess next time, I will use the included Windows 8 "sarcastic" font....
Hahaha naa we got wat you said but good one
sn47som1 is offline
Old 05-28-2015 | 08:41 PM
  #7791
Maximo's Avatar
Default 9853 vs 9886 on a 41005 manifold
SO here is my modified Top Elite 5 being run on both a 9853 and a 9886...this engine loves the 41005 manifold...IMO this engine has one of the best overall powerbands that I have seen
Maximo is offline
Old 05-28-2015 | 09:49 PM
  #7792
sn47som1's Avatar
very tasty work Neal!! When is the new nitro shop thread going to be up if there is going to be one?
sn47som1 is offline
Old 05-29-2015 | 12:07 AM
  #7793
Any test results on the two new conical manifolds?
Matching the manifold on the pipe side seems to give good results.
NitroVein is offline
Old 05-29-2015 | 04:44 AM
  #7794
Maximo's Avatar
Yep I tested the 41032 yesterday.... it didn't perform as well as the 41005 on this Elite 5 engine......The Elite 5 is like a P5 with a Team piston and more aggressive crank timing.....The 2096 also rocked on this engine too...
Maximo is offline
Old 05-29-2015 | 06:36 AM
  #7795
Do you know where you can get RB 2097 pipe?
wichitafc98 is offline
Old 05-29-2015 | 07:32 AM
  #7796
I would be interested in seeing the graph on the Mito 4. That motor is only get more insane as I break it in.
Old 05-29-2015 | 09:16 PM
  #7797
Hoese37's Avatar
So what would be a good pipe for a 421/821B?
Hoese37 is offline
Old 05-30-2015 | 03:02 AM
  #7798
kgombe's Avatar
Unless you are collecting them, I won't pay more than 150 for them, for 2 reasons, you can get a P5 for 215 that has a better rod better carb and better front bearing... abd 150 is a brand new price and being nice cause it's new...
kgombe is offline
Old 05-30-2015 | 04:36 PM
  #7799
Hoese37's Avatar
WTF are you talking about. Reread the question.
Hoese37 is offline
Old 05-30-2015 | 05:59 PM
  #7800
kgombe's Avatar
lol.. i read price... no need to get nasty.. 9853 would be my choice
kgombe is offline
