Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-31-2014 | 08:42 PM
  #7231
cczjordan's Avatar
Is the paloma limited unit? There is a new order coming in so i probably buy 1 as the price is crazy include with pipe n manifold.
cczjordan is offline
Old 11-01-2014 | 04:39 AM
  #7232
rallyebmx's Avatar
Does the keep off .21-4 use a different size rear bearing than the keep off ..21-xl?
rallyebmx is offline
Old 11-02-2014 | 04:10 PM
  #7233
yeah the 21-4 has a 14mm crankshaft and 21-7 has a 14.5mm crankshaft.
Also Novarossi have started messign with the bearing sizes again just so people can't buy 3rd party bearings on the cheap.. "patented".. ugggh...
Eivind E is offline
Old 11-02-2014 | 09:27 PM
  #7234
rallyebmx's Avatar
Thank you. So does the the 21-4 use a 25.8 bearing? I was confused because when I searched 'keep off bearing' under amain a tko 14x28 comes up for 21-4
Old 11-02-2014 | 09:35 PM
  #7235
Yeah we need to separate our apples from our pears here, 21-4BTT uses a 25.8 but I think the Keep Off uses a 26mm bearing where Nova has it patented and it seems to be impossible to buy it anywhere unless you buy the Nova bearing which costs like one million dollars a piece.
As far as I know the only difference between the BTT and the Keep Off 4-ports is the bearing size and therefore slight difference in crank case. Other than that all the parts numbers appear to be the same.
Eivind E is offline
Old 11-02-2014 | 10:53 PM
  #7236
rallyebmx's Avatar
I'm referring to only keep off 21-4. This link from absolute has a 25.8 for the keep off 21-4 i believe. At least that's whats written on the bearing in pic. Just confused why amain has a 14x28 listed for keep off 21-4.
http://www.absolutehobbyz.com/produc...ducts_id=16906
Old 11-02-2014 | 11:37 PM
  #7237
kgombe's Avatar
The keep off uses the same size bearing, in terms of diameter, its the internet race that's different in terms of width. The internal race is 4mm
kgombe is offline
  #7238
kgombe's Avatar
that has to be a typo
kgombe is offline
Old 11-03-2014 | 12:28 AM
  #7239
HomicidalBunny's Avatar
What does?
HomicidalBunny is offline
Old 11-03-2014 | 12:30 AM
  #7240
kgombe's Avatar
http://www.amain.com/TKO-14x28x6mm-C...F-21-4/p384904
14x28 bearing size as written here
kgombe is offline
Old 11-03-2014 | 01:16 AM
  #7241
It says 14x25.8 on the outer race of the bearing in the absolutehobbyz link..
Old 11-03-2014 | 04:50 AM
  #7242
kgombe's Avatar
well duhhh.. did you read his post?
that is what he is saying.. and why he is confused, because too is making a bearing for the same engine and list a different size, thats why i said its a typo...
kgombe is offline
Old 11-03-2014 | 05:17 AM
  #7243
Ok, how big is the difference in width? enough to exclude you from using a 3rd party bearing?
Edit: some googling later and it says:
14x25,8x6mm
vs
14x25,8x5,7mm
So 0.3mm difference in the bearing size.
Eivind E is offline
Old 11-03-2014 | 05:44 AM
  #7244
Pulse_'s Avatar
is there a way to know the factory needle settings of a +4 BTT?
Pulse_ is offline
Old 11-03-2014 | 06:11 AM
  #7245
rallyebmx's Avatar
Thanks for the help on the bearings guys
