Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-25-2013 | 06:39 PM
  #6166
PERROTTO's Avatar
Originally Posted by Eivind E
So guys, question..
Have I diagnosed this correctly if I think it is a leaky front bearing?
-P5XLT engine freshly pinched, only break-in done, new conrod, good crank
-irratic idle, sounds like motorboating "woooorrr wooorrr wooorrr" rather than one continuous stable sound
-at first engine ran fine, but towards the end of the day kept choking, despite being ran sufficiently lean
-seems to be carburated fine, but then after 1/4th lap on the track chokes for no apparent reason
-engine has truckloads of compression obviously
-front bearing is cheapo €4 ebay bearing
I'm thinking this means the cheapo front bearing has let go? Even if it has only less than 1 gallon on it.
Nova fr. Bearing 17011 you could have other problems such as air leaks from fuel system or carb. I always pressure test those under water to be certain.
That would rule out most lean conditions.
PERROTTO is offline
Old 11-26-2013 | 01:00 AM
  #6167
psr's Avatar
psr
What's a ball park btta needle seeting
I run 30 vp 11 percent
psr is offline
Old 11-26-2013 | 01:01 AM
  #6168
psr's Avatar
psr
psr is offline
Old 11-26-2013 | 01:34 AM
  #6169
WildManDriving's Avatar
Running the white 6mm venturi I'm just under flush on both high and low.
Cheers
Michael
WildManDriving is offline
Old 11-26-2013 | 02:16 AM
  #6170
psr's Avatar
psr
Yea cool thanks bud I haven't run the 6 mm one yet
psr is offline
Old 11-26-2013 | 11:14 AM
  #6171
Originally Posted by houston
whoevers idea it was to put one of those cheap ass ones off of ebay on there it was a bad one
I put my hands up, take me off to rehab, I've been a bad bad boy!
I just thought I'd save a few $$$ on the cheapass ebay bearing, actually I got 4pcs for €4.. so that should have been a clue. Lasted 2.5-3 litres, so not even a gallon! But hey, lesson learnt.
Have ordered proper bearing now from Amain.
Eivind E is offline
Old 11-26-2013 | 04:20 PM
  #6172
houston's Avatar
17011 is the best front bearing period
dare I say this on the nova thread but the front bearing from reedy is actually very good in its sealing capability also
viva la novarossi !!
houston is offline
Old 11-27-2013 | 09:29 AM
  #6173
Well the thing is, to install the 17011 then I need to tap the front of the collet on my Hudy tool, well that's what I think anyway, since it protrudes 0.3mm.
So I've ordered some NTN 607LH the blue one that's used on the XZ-B. I know LLH is NTN-speak for special seal against debris entering. What do you think about that bearing?
Eivind E is offline
Old 11-27-2013 | 09:45 AM
  #6174
kgombe's Avatar
Or you can just get a washer that's big enough to fit over the centre race... Or do what I did get a piece of lexan an ream out a hole to fit over the centre race
kgombe is offline
Old 11-27-2013 | 11:30 AM
  #6175
that's a brilliant idea!
Eivind E is offline
Old 11-27-2013 | 11:42 AM
  #6176
kgombe's Avatar
Me brilliant.. Awe shucks...
kgombe is offline
Old 11-27-2013 | 07:29 PM
  #6177
houston's Avatar
Not too hard
houston is offline
Old 11-28-2013 | 09:01 AM
  #6178
Other Q, got a Nova carb off P5XL that's been laying around on my table for about 2 months, now when I try the action on the slide it's like it has a notch sort of halfway, what would be the cause of this? could there be any oil gunked up, or does it mean it could have taken a knock or something?
Eivind E is offline
Old 11-28-2013 | 09:23 AM
  #6179
houston's Avatar
undo the barrel stop screw (idle) and remove the barrel , look around the slide recess's where the stop screw rides for damage . often times some good "lawn darts" while on throttle will wreak havoc on the slide barrel as well as the rod , the piston , etc. , etc.
take it all apart and reoil it anyway Elvind , it should be smooth again
houston is offline
Old 11-28-2013 | 12:13 PM
  #6180
I took it apart, and the slide looks fine, moves fine, everything seems fine. But as soon as I put the rubber boot back on it develops that notchy feel mid way through the motion. Does that mean the rubber boot is at fault?
Eivind E is offline
