EB Mods JS Engine
Old 12-08-2010 | 07:06 PM
  #1426
jpalessi's Avatar
Originally Posted by EBMods
Congrats to Joe Alessi of Lucky7 RC and EBMods for making the move out West leaving all of us to freeze are arse's off in the Northeast.....
I'm ready to jump on a plane now and fly out..
Hey Randy could you call me today please, Joe's on West Coast time,,,, oh wait even when he was on the East Coast he was still on West Coast time... 570-779-0646
Didn't see this,, hahahaha,,,
Don't get to relaxed today, that truck should be showing up with those 3 skids to unload and inventory
none stop chaos.
Ok, the Full Mod .23's are now shipping, Absolute Hobbyz should have some listed and AMain should have them up soon.
FM .23's don't have the bored and filled cranks, but instead they come with a Tungsten Weighted counter balance. We tested the light balance crank verse the heavy balance crank and found the heavy balance crank produces 20% more torque on the bottom over the light balanced crank. And after talking with the Team guys who tested them on the track, they all preferred the feel of the heavy balanced crank over the light balance.
jpalessi is offline
Old 12-08-2010 | 08:53 PM
  #1427
bboard's Avatar
As much as I wanted to hate my JS race prep, it kept on ticking. Bad news was the air filter and exhaust came loose on the qualifing of the first race weekend. It lost pinch and developed a good bit of play in the connecting rod after that. Engine still had good power and some compression, piston had a chip and some scarring on the sleeve. Kept racing the motor through the first gallon then got it pinched and raced another through it, but the play in the connecting was getting exessive and I finally started lossing power so I pulled the engine apart. Through its rough, short life my engine held good power, easy to tune, held tune, got 9-10 mins a tank, and NEVER FLAMED ONCE. Definatly gonna rebuild and hold onto it as a back up while I try this Werks.
bboard is offline
Old 12-09-2010 | 01:11 PM
  #1428
EBMods's Avatar
BBoard, hey thanks for your honesty. I'm not sure why you "wanted" to hate the JS, but I'm very happy that you don't
Maybe give me a call when you go to rebuild that JS. I have a few options when it comes to rebuilding.
Thanks for the support
Ed
EBMods is offline
Old 12-09-2010 | 01:14 PM
  #1429
trax70 guy's Avatar
Default hey ed
Originally Posted by trax70 guy
Hey Ed
Small problem here Crankshaft is worn where the clutch bearings ride on my R/P motor
I have a crankshaft for my older mod motor Will this serve as a good replacement
Both crankshafts have No rod end play and Are in great shape Just want to know
What if any diffrence there might be
thanks
john b
Any thoughts on this?
trax70 guy is offline
Old 12-09-2010 | 01:18 PM
  #1430
EBMods's Avatar
The Mod crank will work, but works better with the lightened piston and rod that the modified engines comes with.
Did you have clutch bearings seize up?
EBMods is offline
Old 12-09-2010 | 02:56 PM
  #1431
trax70 guy's Avatar
Default bearings
no but I did have some come apart I am guessing thats what messed it up
It seems like if the coating whears off there is play where the bearing rides
Either way I love my engines best I,v used so far
thanks ed look foward to meeting you at motorama
Old 12-09-2010 | 04:08 PM
  #1432
Mikey-B's Avatar
Ed, you bringing fuel to motorama? (prob a dumb question)
Mikey-B is offline
Old 12-09-2010 | 04:09 PM
  #1433
EBMods's Avatar
Yes if the bearing fell apart then it's possible it seized before breaking apart. The TiN coating is around 12 microns on surface and 24 microns total because the shaft is cylindrical. 24 Microns is around 0.001" which is giving you that slop between the bearing and crankshaft, if you have the down time send me the crank, I will check it and see what I can do to help.
I can't wait for Motorama
EBMods is offline
Old 12-09-2010 | 04:10 PM
  #1434
EBMods's Avatar
Sir Yes Sir
EBMods is offline
Old 12-09-2010 | 04:32 PM
  #1435
trax70 guy's Avatar
Default crankshaft
What address should I send it to
thanks
john b
Old 12-09-2010 | 08:07 PM
  #1436
bboard's Avatar
Ed
I knew that the shape the piston/sleeve/rod was in that the motor shouldnt have to long of a life ahead, and shouldnt be running as smooth and powerful as it was. I run another gallon and a half, before I just tore it down. YGPM Ed.
bboard is offline
Old 12-10-2010 | 05:35 AM
  #1437
EBMods's Avatar
thanks
john b
EBMods
580 East Main Street
Larksville, Pa 18651
EBMods is offline
Old 12-10-2010 | 07:00 AM
  #1438
EBMods's Avatar
Did you email me? I didn't receive anything yet.
[email protected]
Mikey-B just received your PM, reply sent thanks
EBMods is offline
Old 12-10-2010 | 07:19 AM
  #1439
EBMods's Avatar
A real quick note about the FM .23 crank. The Tungsten weights are just that, Tungsten.
We found during the testing of other cranks that not all use a Heavy Metal like Tungsten. In fact some used a brass or copper slug. Tungsten density is around 19 grams per cc, and the crankshafts we tested averaged 8 grams per cc. If you were to look up the density of brass and copper you would see they average around 8-9 grams per cc. Not much of an increase when you figure the difference.
EBMods is offline
Old 12-10-2010 | 05:35 PM
  #1440
Mikey-B's Avatar
[email protected]
cool, thanks
Mikey-B is offline
