EB Mods JS Engine
Old 04-01-2010 | 06:39 PM
  #451
thanks joe. i have been running the race prep for a few weeks now and love it. i am just a little heavy on the trigger though and heard that the full mod was smoother on the bottom so i thought i would give it a try. can't wait to put these motors to the test outdoors!!
nitroal is offline
Old 04-01-2010 | 06:50 PM
  #452
jpalessi's Avatar
IDK about the FM being any smoother, but it'll certainly spool faster and rev higher.. LMK what you think.
jpalessi is offline
Old 04-07-2010 | 03:56 AM
  #453
1bigshane's Avatar
the js will be my jbrl motor!! cant wait ps i need a good pipe!
1bigshane is offline
Old 04-09-2010 | 06:02 AM
  #454
Default Short or long header
Originally Posted by jpalessi
i'm running a dynamite 086hs with a P5 plug and a 7mm stack.
some of the team guys are running the NR 9901 with a short header and getting great results too. also P5 plug and 7mm stack.
Hi',
Would you also recommend the short header for truggy. I'm running the full mod and will be ordering the NR 9901 pipe. Was wondering whether the long header (better bottom) is needed to compensate for the truggys extra weight.
Jacob
moosemachine is offline
Old 04-09-2010 | 08:59 AM
  #455
jpalessi's Avatar
Originally Posted by moosemachine
Hi',
Jacob
in the truck i would go with a medium to long header on the 9901
jpalessi is offline
Old 04-10-2010 | 01:54 PM
  #456
wallot's Avatar
ballistic. My JS and buddy's Full mod by ED ninja were probably the fastest motors on the track this weekend. Track has very long straights and it was just so easy to catch buggy 50 feet in front of me.
9901 pipe with short header 10:15 on a tank which is not bad considering lot of long straights.
I had to use OD97t as I just could not find any P5 in my pit bag and engine started to behave bit strange with P4 during longer continuous runs. (i never had issues switching between P5 and Od97T in my previous full mod ninjas)
wallot is offline
Old 04-11-2010 | 07:49 AM
  #457
well, had my first race with the full mod. motor was very strong. during practice i could feel it spool up faster than the race prep, but it did seem just a tad smoother coming out the gate. then i had some glo issues. found that the silicone used in the crank had come loose!! cleaned out all the debris anda fter that the full mod was a rocket. it hit so hard and fast that i had trouble controlling it. hopefully i can get the motor taken care of soon so i can get it back for our first pro-series race in 2 weeks. overall i love the js engines.
nitroal is offline
Old 04-11-2010 | 09:35 AM
  #458
akaMTM's Avatar
Joe,
For buggy do prefer the race prep or fully modded?
akaMTM is offline
Old 04-11-2010 | 09:44 AM
  #459
houston's Avatar
yes OS P5 it's a medium plug. I do NOT recommend the OD plugs
the current 9901 is the SS.. the original 9901 was like the old NR pipes.
hmmmm
houston is offline
Old 04-11-2010 | 09:46 AM
  #460
jpalessi's Avatar
Originally Posted by akaMTM
Joe,
I havent run buggy yet this year, but Chap P likes the FM in his buggy and RP in truck.
jpalessi is offline
Old 04-11-2010 | 09:48 AM
  #461
jpalessi's Avatar
Originally Posted by houston
so odonnell plugs suck ? boy i must be confused
monte why you putting words in my mouth.?.?
I never said they suck i just said i DON'T recommend them cause I think the OS plugs are much better.
jpalessi is offline
Old 04-11-2010 | 10:23 AM
  #462
i saw a full mod at the track yesterday in a mbx6 buggy..it certainly moved down the track with authority...it seemed very smooth as well, as there was minimal wheel spin on a slick track..it was a rocket
gtsum is offline
Old 04-11-2010 | 10:27 AM
  #463
jpalessi's Avatar
mine ran yesterday for 3 tanks straight 3
separate times,(90 mins + total).. idles awesome and runs awesome!
I ran a 2041 pipe in my truck and got 12mins to a tank. =D Chad P
was averaging about 11 mins in buggy with a couple different pipes he
tried, and traction was rather low with excessive wheel spin. also the track had 2 straights, 1 like 175' and the other like 100'
jpalessi is offline
Old 04-11-2010 | 10:30 AM
  #464
houston's Avatar
ok , just misread i suppose
houston is offline
Old 04-11-2010 | 10:46 AM
  #465
hambone's Avatar
My buddy went through all his 97t's yesterday. Gave him a OS P5 and it quit popping glow plugs. I have JS, Nova, RB, JP and OS engines and all of them use P4's or P5's without ever having a glowplug issue. Can't remember the last time i had a plug failure.
hambone is offline
