EB Mods JS Engine
Old 09-01-2010 | 06:35 PM
  #1201
Lots o lovin on the SGrid front page slide show
NitroOB4You is offline
Old 09-02-2010 | 03:17 AM
  #1202
JUD's Avatar
JUD
Sytsma runs the race-prep??
JUD is offline
Old 09-02-2010 | 05:17 AM
  #1203
EBMods's Avatar
JUD, Chris currently runs Race Prepped engines.
EBMods is offline
Old 09-02-2010 | 09:35 AM
  #1204
JUD's Avatar
JUD
Nice!
JUD is offline
Old 09-02-2010 | 07:56 PM
  #1205
malcnz's Avatar
Question for you guys:
When I set up the linkage on my Losi EU the carb boot goes in completley when I brake and idles nicely but if I let the brake off and let it idle the boot pops out a tiny bit causing a high idle...any suggestions on a cure?
Thanks.
malcnz is offline
Old 09-02-2010 | 09:21 PM
  #1206
G_WORD's Avatar
Thanks.
Adjust your throttle trim on your radio.
G_WORD is offline
Old 09-02-2010 | 10:14 PM
  #1207
malcnz's Avatar
I wish it was that easy
Have done that but the rod stays out when it goes to idle and you can push the rod back in to lower the idle by hand.
When the buggy is just sitting there not going you can push the rod in and it will pop back out like the carby gator is moving the slide back out.
malcnz is offline
Old 09-03-2010 | 12:36 AM
  #1208
jpalessi's Avatar
ok so while holding the slide in, loosen the dura collar, and adjust it in and tighten to hold it there.
jpalessi is offline
Old 09-03-2010 | 01:14 AM
  #1209
malcnz's Avatar
When you say Dura collar do you mean the collar that surrounds the LS needle?..will try it but seems like the carby gater is forcing the needle out again..does the collar force the gater inwards maybe..immm worth a crack..thanks.
malcnz is offline
Old 09-03-2010 | 03:53 AM
  #1210
jackhammer's Avatar
if it pushes in with your hand ,put on a manual throttle return ,slop in linkage ?
jackhammer is offline
Old 09-03-2010 | 04:02 AM
  #1211
malcnz's Avatar
Thats a good idea as I do usually run a hair band or two but I do find they cut into the carby boot over time but may have to live with it and have a couple of things to try tomorrow..thanks.
malcnz is offline
Old 09-03-2010 | 05:43 AM
  #1212
EBMods's Avatar
I'd try this, and if you have your brakes drag then re-adjust the brake linkages and all should be good.
EBMods is offline
Old 09-03-2010 | 09:12 AM
  #1213
jpalessi's Avatar
No a dura collar is the little silver collar with the set screw that holds your linkage rods on the horn. loosen the set screw and push your carb closed, then while holding it closed slide the collar inward up against the horn and tighten the set screw to hold the link from moving back out on its own.
jpalessi is offline
Old 09-03-2010 | 10:55 AM
  #1214
EBMods's Avatar
Default JS Factory
Just wanted to let everyone know that I leave for the Factory Oct. 2nd and will return Oct. 10th. We have some big things in the works for JS Racing
EBMods is offline
Old 09-03-2010 | 01:45 PM
  #1215
Default hey team
is it ok to use 30% nitro in a standard JS as i run 25% nitro x fuel and was wondering if 30% would harm the engine or make it go even better than it does now.
cheers
Dave:flamin g:
dave1959 is offline
