EB Mods JS Engine
Old 07-08-2011 | 05:30 AM
  #1816
EBMods's Avatar
sorry double post
EBMods is offline
Old 07-11-2011 | 01:56 AM
  #1817
Originally Posted by EBMods
Hello Khaliffen, please check your end points to verify the slide is not over-traveling past the carburetor body opening. You don't want the slide to travel past this point at wide open throttle. If the slide over travels it will shake inside the carburetor body and bind. If this doesn't solve your problem please let me know.
Thank you for the reply.
I have checked my end points several times and the slide does not over travel, nor did it on my old JS engine, where I had the same problem. So unfortunately your proposal does not solve my problem
khaliffen is offline
Old 07-11-2011 | 05:53 AM
  #1818
Sprinkler's Avatar
I have 3 JS Racing engines for sale if anyone is interested.
JS Racing 23 Race Prep Hellfire engine: New in the box sealed in plastic $ 175
JS Racing 21 Engine new in box: $170 w/ Dynamite 086 pipe
$300 for both 21 engines and 2 pipe combos.
Sprinkler is offline
Old 07-11-2011 | 07:00 AM
  #1819
EBMods's Avatar
Your slide may have a burr on the idle screw groove. You will need to remove the slide and check for burrs. Check the inside of the carburetor body as well. If this isn't the problem then maybe contact the factory direct at:
[email protected]
If this is the problem it usally happens when adjusting the idle screw in the clockwise direction, the screw hits the slide which has spring tension from the throttle arm. It's good practice to always open the throttle when adjusting the idle screw.
When you are inspecting the slide also look at the inside carburetor body to see if the slide is being pulled straight. The inside surface will have wear marks from the slide which should be centered.
EBMods is offline
Old 07-11-2011 | 08:00 AM
  #1820
EBMods's Avatar
Originally Posted by blktransam
sure Joe should be held liable 100% but you being the distributer and team owner for the eb mods team should take care of your customers good or bad it sucks but thats is just the way it is.
Ryan just an update, Chris received his replacement engine.
BIG thanks goes out to Aaron Pucci
EBMods is offline
Old 07-11-2011 | 09:43 AM
  #1821
blktransam's Avatar
good deal
blktransam is offline
Old 07-12-2011 | 11:41 PM
  #1822
Good deal, i'm wish i was in US
taminhchau1983 is offline
Old 07-14-2011 | 02:07 PM
  #1823
Ed, is there away to get in contact with you. Ive called the shop and its not working??
Justin Williams
Nightjus is offline
Old 07-15-2011 | 10:53 AM
  #1824
338lapua09's Avatar
Did you try this new number 1-800-678-1037 or [email protected]
338lapua09 is offline
  #1825
minigee's Avatar
anyone have tuning settings for the .23 at 6000ft above sea level and dry climate? Runnin the .23 Hellfire Race Prep, Had it dialed in once then something happened and now it wont run for more than 5 secs. Just looking for a base carb setup at 6000ft asl. Thanks
minigee is offline
Old 07-16-2011 | 05:26 AM
  #1826
Bruce53's Avatar
PM sent on JS Engine and pipe , do you still have them for sale ?
Bruce53 is offline
Old 07-16-2011 | 07:19 AM
  #1827
EBMods's Avatar
Please check the piston skirt isn't broke on the exhaust port side. On some engines at TDC the piston skirt travels past the bottom of the port and will catch on the down-stroke and break.
See link below:
http://ebmods.com/light.htm
Sorry Bruce no engines or pipes in-stock. Try Absolute Hobbyz or A Main Hobbies.
EBMods is offline
Old 07-16-2011 | 11:31 AM
  #1828
slow supra's Avatar
Thumbs up New EB engine?
Hi Ed, do you have an ETA as to when your new engine will be for sale? Thanks, Jim
slow supra is offline
Old 07-16-2011 | 11:54 AM
  #1829
EBMods's Avatar
ETA around Christmas / New Year we should have production started on the new .21 engine. Team Drivers and Hobby Shops will have samples to test in Mid-October. This engine will be completly made in the USA, with some of the parts machined in-house at EBMods and other parts out sourced to machine shops.
As we get closer to testing I will have updates and more info about the engine.
EBMods is offline
Old 07-16-2011 | 12:03 PM
  #1830
EBMods's Avatar
Oh and I have to say I'm VERY excited about this,,, I wish we could speed the process up but small steps first, with lots of testing. It's an amazing feeling everytime we finish a part!!!!!!
EBMods is offline
