EB Mods JS Engine
#1802
http://www.rctech.net/forum/classic_...milies/nod.gif
anyone know why i cant get smiles ?
#1803
That's good stuff Noddy2.
I have tried almost all the pipes and glow plugs on that list you made.
My favorites are a OS P4 Plug with a Reckward 2041 pipe.
As far as tuning it is going to vary by fuel, clutch choices, and air density that people are running and the way the weather is on a certain day.
#1804
#1806
Ed,
With all the recent changes with the JS engine line over the last month, I wonder where this leaves me. I have been waiting patiently for some news, while your were trying to locate an engine from a dealer and have not heard a word. Will I ever receive a replacement engine from you?
#1807
Ed,
from him.......keep trying but i doubt ull ever here anything
#1808
I replaced your engine, that's why you were told by JOE ALESSI over 3 months ago that he had your replacement engine. Joe then sold your engine not telling me or you, nor did Joe pay me for that engine. So now I'm stuck in the middle.
#1809
I've responded to your emails,, not sure why you didn't get them? Did you call 1-800-678-1037, I talk to people everyday when they call.
#1810
Hello Chris, I really don't know what to say.
no matter what happened, JOE worked for YOU so you are liable for his actions good or bad give the man a engine good god!
#1811
Chris, here is the email for the factory [email protected] I'm sure they will send you a replacement just as they did for Tony Newland when his engine blew the clip out with 3.5 gallons on it, yours had less than a gallon.
Ryan if I had an engine I would send him another one licky split.... I think Joe should be held liable for his actions as well don't you?
The factory owes me money for all the engines I returned to them, so far I have replaced close to $20,000 out of my pocket on factory defective engines.
#1814
i'm locate in Vietnam use this engine with JP1 pipe
this is good enigne i'm using the second one(the first one was damaged when sand come inside the engine because of poor air filter) and seem to be it will still be my next choise
after shipped to Vietnam it cost about 270$ for the stock one
#1815
Hello Khaliffen, please check your end points to verify the slide is not over-traveling past the carburetor body opening. You don't want the slide to travel past this point at wide open throttle. If the slide over travels it will shake inside the carburetor body and bind. If this doesn't solve your problem please let me know.
