Like Tree1Likes
Sirio engines thread
Old 05-19-2006 | 07:23 AM
  #1276
Corse-R's Avatar
Originally Posted by Grinder
The engine has more power than any .12 currently out on the market, and the mod is even faster. .
You guys are completely insane... Evo3 STi is enough quick for 99% of us.
P.D: Would like to see one of your Evo3 tearing up the track.
Corse-R is offline
Old 05-19-2006 | 08:29 AM
  #1277
Motorman2 is offline
Old 05-19-2006 | 04:42 PM
  #1278
itchy b's Avatar
from what i've read about josh cyrul's review on the new orion motor, looks like there might be a serious challenger to the crown there!!
why dont we all just buy both
itchy b is offline
Old 05-20-2006 | 04:34 AM
  #1279
Dynamite's Avatar
I think josh would race the motor he gets the best deal from really, and i wouldnt blame him for it. there are a number of motors he could use and get the same results with being a driver of his abilities and the knowledge he has.
I wouldnt mind trying either of the two new motors myself.
Dynamite is offline
Old 05-23-2006 | 11:00 PM
  #1280
has anyone had any problems with the crank in the .12 sti ???
ae_ntc3 is offline
Old 05-23-2006 | 11:09 PM
  #1281
wad's Avatar
wad
I put 3 gallons on one STI already, no problems at all, it still working strong, really good motor
wad is offline
Old 05-24-2006 | 11:24 PM
  #1282
kickass's Avatar
Default fixed
This crank problem was fixed way before the STI, it was the first batch of evo 111 cranks. This was sorted last year.
Cheers
Alex.K
kickass is offline
Old 06-03-2006 | 06:38 PM
  #1283
Does anybody have the bearing sizes for the EVO STI? I'm planning on changing to Ceramic bearings.
Thanks,
Jeff
Proteus is offline
Old 06-05-2006 | 10:58 PM
  #1284
Did you replace the rod? And will a VR12 plus would work well with it?
trebronpay is offline
Old 06-06-2006 | 12:45 AM
  #1285
wad's Avatar
wad
I didn't replace the rod; the VR12 Plus works really good with Sirio Motors.
I haven't try it but I know people who tried and found that the power of this combo is awesome
wad is offline
Old 06-06-2006 | 08:56 AM
  #1286
Team Kamikaze's Avatar
I didn't replace the rod; the VR12 Plus works really good with Sirio Moto haven't try it but I know people who tried and found that the power of this combo is awesome
I know Walter, You did not replace the rod, but you replace the engine J/K
Team Kamikaze is offline
Old 06-06-2006 | 09:02 AM
  #1287
Thanks Walter.
Old 06-06-2006 | 05:03 PM
  #1288
Is running a Novarossi plug in the STI inadvisable?
Thanks,
Dave.
DaRollaRacer is offline
Old 06-06-2006 | 06:00 PM
  #1289
wad's Avatar
wad
Thanks,
Dave.
On Sirio engines you should use Sirio or OS plugs; Novarossi plugs will fit but they don't seal properly.
wad is offline
Old 06-06-2006 | 06:52 PM
  #1290
kidDynomite's Avatar
Thanks,
Dave.
Josh told me last weekend, that if your going to use any brand plug, try to stick with it. Most plugs have different tapers which basically means that using different plugs could eventually open up the tap and then you loose the tight fit. Makes sense, and I'm pretty sure most of us don't even realize these nano details that could cost us a race or $ in the long run.
He did also say that if you need to change to a different brand plug, you should replace the head.
kidDynomite is offline
