Sirio engines thread
#1306
Thanks!
What's the price for a rebuild btw? Thinking of this VS the EB mods TZ. One crew says the OS lasts long...another says no..same with the Sirio. I never experience or heard of any issue of this with the Evo2 or original Sirio.
#1307
Originally Posted by HarKonnenD
Thanks!
What's the price for a rebuild btw? Thinking of this VS the EB mods TZ. One crew says the OS lasts long...another says no..same with the Sirio. I never experience or heard of any issue of this with the Evo2 or original Sirio.Seen other OS's and are quick, but are modifieds.
#1308
Originally Posted by Corse-R
My actual experience is with Sirio EVO3 and is a real screamer, no matter if you get the normal, the STI or a modded one, is a real screamer and you'll not have to have any concern regarding their performance.
#1309
here is a list of all S12 parts that are IN STOCK at Kyosho America. Your loacal hobby shop can get order these parts for you
Code:
Item Number Description Retail S12012213 S12 EVO 3 RACING HEAD 41.99 S12012300 S12 MT HEAD 13.99 S12021200 STD PLUG UNDERHEAD 7.99 S12021211 "TURBO" PLUG UNDERHEAD 9.99 S12030010 GASKET KIT 4.99 S12041211 S12 3 PORTS "ABC" PISTON AND 85.99 S12041227 S12 EVO 3 5 PORTS "ABC" PISTO 109.99 S12051020 PISTON PIN 13.99 S12051032 S12 EVO 3 PISTON PIN 21.99 S12060010 PISTON PIN RETAINER 5.99 S12060012 PISTON PIN RETAINER 5.99 S12060100 EXHAUST SPRING 12.99 S12060101 SILENCER SPRING 12.99 S12070020 S12 CONROAD 32.99 S12081201 S12 THREADED CRANKSHAFT "RACIN 46.99 S12090010 FRONT BALL BEARING 8.99 S12090230 REAR BALL BEARING 15.99 S12090231 REAR BALL BEARING "RACING" 29.99 S12100010 CONE STD 6.99 S12111103 S12 SE CRANKCASE 92.99 S12111111 S12 EVO 3 RACING CRANKCASE 110.99 S12121100 SE BACK PLATE 7.99 S12121102 BACK PLATE 7.99 S12130011 O-RING KIT 2.99 S12140021 HEAD SCREWS 3.99 S12140022 BACK PLATE SCREWS 3.99 S12140024 CARBURETTOR RETAINER 2.99 S12140025 SE HEAD SCREWS M3 x 14 3.99 S12140123 CARBURETTOR RETAINER 4.99 S12160001 CARBURETTOR BODY 68.99 S12160002 CARBURETTOR THROTTLE 17.99 S12160003 BASE SPEED NEEDLE 7.99 S12160004 FULL SPEED NEEDLE 4.99 S12160005 INTAKE FUEL SET 5.99 S12160006 BASE SPEED ADJUSTING SET 6.99 S12160007 BASE SPEED ADJUSTING SCREW 4.99 S12160008 UNIBALL BALL JOINT 5.99 S12160009 ALUMINIUM RINGS FOR INTAKE FUE 3.99 S12160010 O-RING CARBURETTOR SET 6.99 S12160011 DUST PROTECTION RUBBER 6.99 S12160012 CARBURETTOR BODY DOUBLE ADJUST 68.99 S12160013 BASE SPEED ADJUSTING SCREW 4.99 S12160014 REDUCER ø6 7.99 S12160015 REDUCER ø5 7.99 S12160016 REDUCER ø5,5 7.99 S12160017 CARBURETTOR THROTTLE 17.99 S12160018 BASE SPEED NEEDLE 7.99 S12160020 RETURN SPRING 4.99 S12160021 UNIBALL BALL JOINT 5.99 S12160022 DUST PROTECTION RUBBER 6.99 S12160210 O-RING CARBURETTOR SET 6.99 S12161010 S12 STD ROTARY CARBURETTOR 69.99 S12161040 S12 DOUBLE ADJUSTMENT SLIDING 79.99 S12170001 SHAPED EXHAUST GASKET 5.99 S12170003 TEFLON SPACER S12 "SHORT" 7.99 S12170004 TEFLON SPACER S12 "LONG" 7.99 S12170005 EXHAUST SILICON RING 8.99 S12200013 FLANGED EXHAUST "EVO3" 50.99 S12T3ISTI SIRIO 2,1 cc EVO 3 3 PORTS SL 449.99
#1314
Originally Posted by ziggy12345
Hi
Where can I buy a EVO3 STI T3 online (Far East?)
Cheers
Cheers
#1315
#1320
Guys just got my sti today....busted them open...they look real nice..I like what they did with the sleeve....and crank looks sweet also....what should i expect out of this motor from everyones experiance...also they seemed to be very clean on the inside from factory thats a plus
1Likes
Hell yeah!
