Like Tree1Likes
Sirio engines thread
Old 08-14-2006 | 01:33 AM
  #1456
itchy b's Avatar
Originally Posted by DaRollaRacer
Hi Itchy,
I had problems making run time at the Great Lakes Challenge because the track was huge. At smaller tracks, I'm not worried at all. I'll get this thing sorted out.
I'll be giving the Novarossi 2630 another try this coming weekend. It'll be at a track similar in size as the GLC.
Hey Robert, would you ever give a 21T second gear pinion a try for the Toledo track?
Dave
the runtime i'm getting is on a huge track too but 1 of the guys there uses your type of pipe and told me that the sti uses more fuel with the new novarossi pipe
itchy b is offline
Old 08-14-2006 | 02:26 AM
  #1457
M7H's Avatar
M7H
Originally Posted by Slo-MTX4
Ok guys i have a bit of a problem atm with my evo3. After a straight it seems run on a bit before it settles back to idle.
Common "problem" with engines in general....
lean out the bottom end, and lower the idle rpm.....
You can try this on the startbox.
When engine goes back from full rpm, listen to it.
If it idles high and after a few seconds goes down in rpm, the bottom end is to rich.
If it idles low, and after a few seconds the rpm goes up, the bottom end is to lean.....
M7H is offline
Old 08-14-2006 | 05:36 AM
  #1458
Hi Itchy,
Dave
what % nitro did you use?
-try backing off the clutch a bit so the engine doesnt rev up as much before it engages.
-use a bit longer fuel line
all of these only give you a few more seconds of runtime but it all adds up!
ae_ntc3 is offline
Old 08-14-2006 | 12:31 PM
  #1459
ziggy12345's Avatar
Just running in my STI! Man thats a long pipe! (the sirio one!)
Cheers
ziggy12345 is offline
Old 08-14-2006 | 02:48 PM
  #1460
wallyedmonds's Avatar
you would think but this is a sirio.
wallyedmonds is offline
Old 08-14-2006 | 03:01 PM
  #1461
litespeed-dom's Avatar
I don't know, that seems to have been the common perspective that I can't really agree. Lately the motors we have tuned when it comes in reving bad out of hell, it isn't the bottom too rich, it's actually too lean. Running WAY hot. When we richen the bottom, the temp becomes a lot more controllable.
Dom
litespeed-dom is offline
Old 08-14-2006 | 03:22 PM
  #1462
Slo-MTX4's Avatar
Yeah i tend to agree with Dom on the bottom being to lean as opposed to too rich. I am hoping that it was just the o'ring that the carb seals into crank case with. For some extra saftey i have put a small amount of ultra blus sealant around the flange. Has anyone else had this problem?
Slo-MTX4 is offline
Old 08-14-2006 | 03:26 PM
  #1463
robert maestrey's Avatar
Hi Itchy,
Dave
No I wouldnt....21 is too small..I wouldnt go smaller than 23 pinion 55 spur maybe 56 .....also guys the spurs you guys are listing above seem to be incorrect. .......1st gear pinions comes in 15,16,17, 2nd pinions 20,21,22,23
1st spur 59,60,61 2nd spur 55,56 these are the only gears im aware of currently shown on the rollout chart for the rrr... remeber guys refer to your rollout chart accordindly to get the correct amount of gear your looking for when cutting your tires to the desired split
robert maestrey is offline
Old 08-14-2006 | 03:31 PM
  #1464
You should always verify for yourself......try a bunch of different pipes and see what works best for you....remeber there are alot of factors that make the car run certain way and the pipe is only one of them
Old 08-14-2006 | 10:00 PM
  #1465
itchy b's Avatar
yes i agree, i've tried both the sirio pipe and the nova pipe back to back and the novarossi pipe seems to pull harder through the range but i broke the front belt on the car before i could do a runtime comparison
then it was time to fix the car and change the motor so i could give it to KICKASS RACING for modding
itchy b is offline
Old 08-15-2006 | 02:54 PM
  #1466
Tim Johnson's Avatar
Exclamation
Hello all, here is a list of parts that have just hit the USA warehouse:
THESE ARE NEW TO THE USA WAREHOUSE
Code:
S30123111	ROTO START BACK PLATE '05
S30150012	ROTO START ONE WAY BEARING '05
S30084010	ROTO START REAR SHAFT '05
S12012214	S12 EVO 3* STI RACING HEAD
S12041228	S12 EVO 3 STI 3 PORTS "ABC"* PISTON AND LINER
S12070023	S12 EVO 3 STI CONROD
S12111112	S12 EVO 3 STI RACING CRANKCASE
S21041235	PR EVO 2 STI 7 PORTS "AAC" PISTON AND LINER
S21070012	STI "RACING" CONROD
S21081302	PRO STI CRANKSHAFT
S21113203	PR EVO 2 STI CRANKCASE
S21013213	BX STI RACING HEAD
S28013201	STI "RACING" HEAD
S28043122	STI 5 PORTS PISTON AND LINER
S28070012	STI "RACING" CONROD
S28083111	STI CRANKSHAFT
S28113101	STI S28 CRANKCASE
S001720006	STD GLOW PLUG S6
S001720007	STD GLOW PLUG S7
THESE ARE RESTOCK
Code:
S12070022	S12 EVO 3 CONROD
S001720127	"TURBO" GLOW PLUG S7
S12090231	REAR BALL BEARING "RACING"
S12130010	O-RING KIT
S21060000	S21 PISTON PIN RETAINER
S21170001	SHAPED EXHAUST SILICON
S21043224	5+2 PORTS BK EVO2 "ABC" PISTON
S23082000	S23 BACKPLATE SHAFT
S12041211	S12 3 PORTS "ABC"* PISTON AND
S12060012	PISTON PIN RETAINER
S12090021	FRONT BALL BEARING
S21013202	BK EVO2 RACING HEAD
S21050012	S21 "PRO" PISTON PIN
S21090010	S21 FRONT BALL BEARING
S21090220	S21 REAR "RACING" BALL BEARING
S23121101	S23 TX BACKPLATE
S23161040	S23 STD CARBURETTOR ø 9 (CAST
S23200002	S23 STD REVO MANIFOLD
S27070010	"STD" CONROAD
S30084000	ROTO START REAR SHAFT
S12T3ISTI	SIRIO* 2,1 cc EVO 3 3 PORTS SL
Tim Johnson is offline
Old 08-15-2006 | 02:57 PM
  #1467
Corse-R's Avatar
Sorry... just realized it.
Corse-R is offline
Old 08-17-2006 | 07:39 PM
  #1468
Originally Posted by HarKonnenD
Hmm so it's all mumbo Jumbo then eh? Well, if this LHS here can get me the parts then Sirio it is. I'm just wondering if it will do great with the Nova CTF #7 plug I've been using.
use sirio plugs and this is not an add they work better in sirio motors my novas i use nova plugs i dono why but they do.
Old 08-19-2006 | 08:21 PM
  #1469
Originally Posted by wallyedmonds
on a small track try one up on the spurs 54-60 im gona try stock on a big track next week.
and stock works great,runtime was about 6min on a big track so im happy now lol, SIR pipe
Old 08-20-2006 | 05:55 PM
  #1470
ok now im not happy,the crank broke just like others iv seen,this sucks cuz i did not do anything to make it break,it was runing at 235 and fine with lots of power and smoke so idono.
