Like Tree1Likes
Sirio engines thread
Old 08-25-2006 | 05:19 PM
  #1486
wallyedmonds's Avatar
Originally Posted by DaRollaRacer
Mileage wasn't that big of a deal in Hamilton, it was in Toledo though. Making runtime there was so much harder.
Dave
oh yes i hurd and im happy again im getn a new motor from k mart umm kyosho usa.
wallyedmonds is offline
Old 08-25-2006 | 05:21 PM
  #1487
Originally Posted by Corse-R
Sometimes, runtime is a problem of the tracks we're running, so no matter what you do... is a throttle time problem (faced it and was unable of doing more than 4:45... ).
If my experience can serve to you. Did from a 5mm venturi a 5.3mm and used an INS box. This helped me to make 5 minutes and very few seconds, lost a tad of power, but at least was able to finish the qualififiers.
a 6mm may be better gota get one but where.
Old 08-26-2006 | 06:00 AM
  #1488
Tim Johnson's Avatar
Tim Johnson is offline
Old 08-26-2006 | 06:59 AM
  #1489
robert maestrey's Avatar
Originally Posted by Tim Johnson
Very
robert maestrey is offline
Old 08-26-2006 | 07:45 AM
  #1490
Corse-R's Avatar
Under the rules I race, the max venturi allowed is 5.5mm of diameter and I wasn't capable of doing 5 minutes and you told me to put a 6mm venturi?
And regarding your last posts on this thread:
Corse-R is offline
Old 08-26-2006 | 11:27 AM
  #1491
its a joke guys just like ppl saying K CAR its just a joke
Old 08-26-2006 | 11:29 AM
  #1492
ya the rule is 5.5mm but if you run no rules do you think 6mm will work better.
Old 08-26-2006 | 11:34 AM
  #1493
and i will say im very thankfull to kyosho for giving me a new motor. i know it would be much harder if it was another motor comp.
Old 08-27-2006 | 06:53 PM
  #1494
Osiris 75's Avatar
What would be the areas on the engine where it would suffer an air leak? And if so, how can I repair it?
Osiris 75 is offline
Old 08-27-2006 | 08:39 PM
  #1495
I have yet to suffer any..so I don't have any specific area to look for..but I would say if a leak would occur most likely the carb area..needles..always check your orings for scaring. Prevent maintenance is your best bet ..hope this helps.
Old 08-28-2006 | 06:59 AM
  #1496
Osiris 75's Avatar
Would I need to put something on the carb to seal it, because I didn't?
Old 08-28-2006 | 07:07 AM
  #1497
Corse-R's Avatar
Nope, what you need to do is order a carburetor rebuild o-ring set and change them, usually the problematic ones are the ones are mounted in the LSN needle, change them in first instance and 99% your problems are a matter of the past.
This kit is very cheap and is handy to carry a bag of those, can spare of many problems and rough times at the track.
Corse-R is offline
Old 08-28-2006 | 11:20 AM
  #1498
Osiris 75's Avatar
Ok. Where can I order some from?
Old 08-28-2006 | 11:29 AM
  #1499
litespeed-dom's Avatar
S12 13011 O-RING KIT.
Have any of your local Kyosho dealers order it direct from Kyosho America.
Dom
litespeed-dom is offline
Old 08-28-2006 | 01:22 PM
  #1500
Thumbs up
PM me with your zip code and Area code, and i can find a shop near you
