Sirio engines thread
#1504
It's still kinda hard for me to tune the engine, being that this is my first engine other than an OS. As far as the HSN, should the screw be close to the edge, or is it closer to the middle. I turned it out from closed 4 times, but it still seems to be running hot.
#1505
#1510
Originally Posted by Slo-MTX4
How much usage are you guys getting before you change piston and liners?
the motor is super fast but still gets stuck up top
#1511
Originally Posted by robert maestrey
I feel that the my sirio still has breaking in to do and im on my second gallon
They hold the compression great (those ones with less pinch). I've passed around 10 litres of fuel to my original STi and finally that s*cker has finished their break-in, time to tear the track, was really quick, but now is the same with less temp.
Planning to change the main bearing at least. After the nightmare of the past 10 litres they look fine, but main bearing is cheap and I get an extra of security for not blowing it.
#1513
Does anyone have any feedback on the following 3-port comparisons?
- STI vs O.S. TZ stock/modified
- STI vs Mega .12 ZX/DSII
- STI vs JP stock/modified
- STI vs WASP Rev CRF
I race on a 150' x 60' technical track with only one straight. I'm particularly interested in how the bottom end to mid range compares between the two engines. I'm looking for strong acceleration when exiting turns in the infield.
Thanks in advance,
Rainer
Thanks in advance,
Rainer
#1514
Thanks in advance,
Rainer
Thanks in advance,
Rainer
#1515
Originally Posted by wallyedmonds
well the sti is better than the os,sti is faster than the mega,jp is a better motor than the sti, and what a wasp hmmm i think the os is better.
Thanks Wally! I needed a good laugh today.
for this track i think the mega for the bottom end power or the jp stock, the track is short or maybe a LL3 but i will say the STI will work good and its cheap just dont crash hard.the STI works better on bigger tracks.
1Likes
