Sirio engines thread
#2251
the only difference between the evo4 and the evo4sti is that the sti has ceramic bearings
and as for the conrods the conrod on the evo4 is lighter and has less material around the top connecting hole
also word is that sirio is going to change the material of there cranks they are getting rid of the black hard annodized crank in favour of a new material similar to what the novas use
#2252
#2253
Thanks bro...did u notice that the Sirio clutch spring memory is very short. I ahve used it for a race and managed to TQ but after the race if found out that the length shorthen from 9.8mm to 9.7mm. I was i little surprise because i only tighten it at 0.7mm with a 0.4mm gap.
Is there any specific instruction or method to setup the sirio clutch assembly?
#2256
#2257
na , its not the clutch setting or tune ,chris and mine and a few others are short on run time and there on the lean side of happy, compared to the evo3 sti the run time is not there ,on a large track about 30 seconds short, hopefully an answer will come soon
#2261
OS MAX SPEC 2!!!!!!!!THE BEST ENGINE AROUND!!!!!!!
Just kidding nikoskar!Good luck at your first race today.I'm sure Sirio will kick some ass
#2262
Chad, Andrew and Chris changed the bearings to the ceramics and their run time issues were solved. Double check, but i think this is all they did.
#2263
Trying to find the factory needle settings for this motor and trying to find out what pipes the factory kyosho guys are using with this motor in there truggies. Having a tough tuner start over from scratch Just forgot to count the needles before we started. Having a lean bogging problem. No matter how rich I put the motor. And has anybody tried McCoy plugs in there sirio motors. Thank you Matt
#2264
#2265
1Likes
