Like Tree1Likes
Sirio engines thread
Old 04-24-2008 | 05:30 PM
  #2281
Help identify this Sirio motor...I love this little thing, but would like to know what internals i can replace with. I'm in my 2 finals weeks, so i won't have time to take it off and apart, so these will have to do for now. 3 port, AAC, Turbo head, turbo scoop on crank, no putty ramp, knife con rod, no markings on case except for made in italy, had on shim i think, black composite carb with silver restrictor, 3 needle adjustment.
Baedarlboo is offline
Old 04-24-2008 | 06:05 PM
  #2282
GMartinez's Avatar
That's a T3 version which Is no longer in production you use a piston & sleeve from the evo 3 version
GMartinez is offline
Old 04-24-2008 | 08:27 PM
  #2283
afm's Avatar
afm
Your engine is an early production Evo2, coded
S12 TRP PRO E if it is EFRA spec or
S12 TRP PRO I if it is IFMAR spec
The PRO series came with AAC sleeve, versus the non PRO that came with ABC sleeves. Performance was the same, being the AAC more difficult to tune correctly.
Early production EVO2's came with that slim tall light blue cooling head with no EVO" engraving, later they came with the 52mm oversized coolin haed with different engraving, but that was the only change, internals where the same.
All parts are interchangeable between all S12TRP's engines.
Some part numbers:
S12041213 PISTON-SLEEVE EV2 3 PORTS ABC
S12041214 PISTON-SLEEVE EV2 3 PORTS AAC
S12051020 PISTON PIN
S12060010 CIRCLIPS
S12070020 CONROD
S12081200 CRANK EV2 EFRA
S12081300 CRANK EV2 IFMAR
S12090010 FRONT BEARING
S12090230 REAR BEARING
S12012202 52MM COOLING HEAD
I don't know if those parts are available, but you might try the search with the PN's. or maybe contact Kyosho of America who I think are the USA dealers, and maybe see with them if current Sirio engine parts are interchangeable.
I'm long gone from Sirio engines so I can't help you more. They are great engines though, just changed brands to whatever has more support and part availabilty around here.
Regards
AFM
afm is offline
Old 04-24-2008 | 11:17 PM
  #2284
thanks a bunch guys! So i can use evo 3 internals?
Old 04-26-2008 | 04:26 PM
  #2285
iiistyler's Avatar
Can anybody help out with a part number for the carby of a S12-T3-EVO4
Also is the carby the same as an evo3 sti ?
Thanks in advance
iiistyler is offline
Old 04-28-2008 | 10:32 AM
  #2286
bugnet's Avatar
Hi,
someone have details or a how-to set sirio power clutch for .12 engines ?
manual that comes with it, I didn´t understand if should shim inside, outside, none or what to do,
thnks
bugnet is offline
Old 04-28-2008 | 03:32 PM
  #2287
iiistyler's Avatar
Originally Posted by bugnet
Hi,
thnks
Just set it up the same as the 2D clutch
shim the outside first then shim inside so clutch bell doesnt ride on the shoe
Old 05-02-2008 | 12:57 AM
  #2288
Questions?? new .12 engine
Hey guys im new to the game and thinking of upgrading my engine in my rrr,so i was thinking going with sirio.So i was wondering which one to go for. i will also be needed a pipe and clutch for it.Any help would be good.thanks in advance
elche_83 is offline
Old 05-02-2008 | 02:35 AM
  #2289
rcabj's Avatar
frankly i myself not yet use these 'monsters' but if u r serious esp. for racing get the sirio evo4 sti paired with the sirio 2611 pipe, as for the clutch the stock RRR already good enough. if u want more get the sirio clutch set.
rcabj is offline
Old 05-03-2008 | 05:16 PM
  #2290
Thanks you for the help
elche_83 is offline
Old 05-12-2008 | 08:17 PM
  #2291
Does anybody know the differences between the EVO 2 and the EVO 4 motors ? The reason why I ask is because I have an EVO 2 motor that is litterally a missle. It really rips up some of the current modified motors at my track because it was used at the worlds in Brazil for touring car back in 2004 and made the A-main . It still has alot of compression. Any help would be appreciated. Thanks.
( Here's afew photos of the car )
Attached Thumbnails Sirio engines thread-img_5476.jpg   Sirio engines thread-rrr.jpg
Paul D. is offline
Old 05-14-2008 | 02:12 AM
  #2292
lim's Avatar
lim
EVO2 and EVO4 engine are totally different engine...you have different cylinder, rod, bearings...so all the parts are different.
According to me if you are satisfied using an EVO2...you will be really surpriesed when you'll test the new EVO4, standard or STI version, according to me it's one of the best engine made by Sirio, in particular if you use a Sirio or Capricorn clutch system.
lim is offline
Old 05-14-2008 | 02:49 AM
  #2293
Roger's Avatar
Go for the werks motor. You'll like the power band and it's also sirio based.
Roger is offline
Old 05-20-2008 | 05:12 PM
  #2294
Gseventeen's Avatar
Default Any Warranty
Just broken the end off the crank that holds the conrod in an evo3 sti,
has only had two litres through it.Motors a weapon, can anyone tell me do sirio replace this sought of damage under waranty,i been told its a common occurance with this donk!
Gseventeen is offline
Old 05-20-2008 | 07:14 PM
  #2295
Good luck....
but if you get frustrated, and need another crank, and parts. Contanct Uriah
www.murnanmodified.com
