Like Tree1Likes
Sirio engines thread
Old 11-03-2008 | 03:15 PM
  #2431
Michael_T's Avatar
Does anyone know the sizes of the two bearings that go into the Sirio power clutch?
I have mis-placed mine and can't find the size of the two bearings to replace them.
Thanks.
Michael_T is offline
Old 11-04-2008 | 06:55 AM
  #2432
Thanks.
Do you mean power clutch for .12 engine?
The bearing size in clutch bell is:-
Small one: 8 x 5 x 2.5 mm
Big one: 10 x 5 x 4mm
Hope this helpful.
kenre is offline
Old 11-04-2008 | 07:04 AM
  #2433
Got it from Italy. More pictures of xXx here.
Attached Thumbnails Sirio engines thread-9.jpg   Sirio engines thread-8.jpg   Sirio engines thread-5.jpg   Sirio engines thread-2.jpg   Sirio engines thread-3.jpg
kenre is offline
Old 11-04-2008 | 07:16 AM
  #2434
More picture.
Attached Thumbnails Sirio engines thread-1.jpg   Sirio engines thread-6.jpg   Sirio engines thread-7.jpg   Sirio engines thread-12.jpg   Sirio engines thread-dsc01097l.jpg
kenre is offline
Old 11-04-2008 | 12:02 PM
  #2435
Michael_T's Avatar
Hope this helpful.
Excellent, thank you.
Old 11-05-2008 | 03:07 AM
  #2436
barg's Avatar
Have you tried it yet? Where do you race? What country is Austrilia?
barg is offline
Old 11-05-2008 | 03:22 AM
  #2437
does anyone know how it performs compared to the Evo 4.
NinjaRacer is offline
Old 11-05-2008 | 10:55 AM
  #2438
Speyederjedi's Avatar
Anyone know if this new Sirio XXX has any teflon coating? Doesn't look to different from the Evo 4 STI.
Speyederjedi is offline
Old 11-06-2008 | 11:10 AM
  #2439
Oops! thanks for advise.
kenre is offline
Old 11-06-2008 | 11:27 AM
  #2440
Hello, are you mean the back plate on engine? I know only EVO3 Sti have Teflon coating on back plate.
Con-rod and pin is compatible with EVO4. Not sure crankshaft have any modifiy compare Evo4.
Piston and cylinder is changed, case have back coating with some modified. We can say this is Evo 4.5??
One special thing is the Exhaust is new model in the kit.
Hope this helpful.
kenre is offline
Old 11-06-2008 | 07:18 PM
  #2441
jk1152's Avatar
Hope this helpful.
From the pictures it looked like the Sirio 2611 that ran at the worlds (fat exhaust tip) that can not be ran in events anymore. This exhaust is not new.
jk1152 is offline
Old 11-08-2008 | 09:49 PM
  #2442
boy2rc's Avatar
Hi, where on-line shop I can find S12-T3 I STI EVO3 rear (main) bearing? Thank you!
boy2rc is offline
Old 11-10-2008 | 04:05 PM
  #2443
blown sv's Avatar
Hope this helpful.
yes the rod ,piston ,sleeve, back plate and crank are the same as evo 4 and sti version, the only difference is the crank case is coated and the head button is different , probably to get a better seal ( similar to the R3 RB head button) and the crank case has some extra cooling holes drilled into the fins,and also comes with ceramics same as the sti,
and that pipe has been around for a while now ,
and xxx sounds much better
blown sv is offline
Old 11-10-2008 | 04:28 PM
  #2444
Marcus Falconie's Avatar
Default B3 help
Can any of you Sirio (Werks) guys help me out. Is the head bolt pattern the same as a Novarossi or Picco. I want to get the Trinity Phatt Head for the motor because they are only $35 but they only sell them for Novarossi, Picco,and OS. The guy at osrocketracing.com said his heads would fit but they are $65. This is for a B3, I just want more cooling than the little 8 fin head the motor comes with. Thanks for your help. PS This is for Buggy
Marcus Falconie is offline
Old 11-19-2008 | 06:01 PM
  #2445
XXX engine is available in the USA now. I got one today.
Scott Fisher is offline
