Like Tree1Likes
Sirio engines thread
Old 06-22-2006 | 02:22 AM
  #1291
Hi there guys,
Just wandering,, i have ran in my Evo3 STI and had 1 club day racing with it, I was told that i should replace the rod NOW. Should I???
Also i was told that people are replacing the Rods with Standard EVO 3 Rods as they are exactly the same and they are cheaper??
Thanks in advance
KYOSHORACER is offline
Old 06-23-2006 | 02:45 AM
  #1292
Corse-R's Avatar
Originally Posted by KYOSHORACER
Hi there guys,
Thanks in advance
The conrod should be changed after the break-in when you have leaned your engine. This is mainly caused because during the break-in, the effort made by the conrod is extreme and the materials are surely fatigued (doesn't matter if looks good, changing it is a cheap insurance).
Well... if they made an effort on making a series of blueprinted engines all of them with the exact tolerances is somewhat nonsense to put a non-blueprinted part.
Corse-R is offline
Old 06-25-2006 | 01:22 AM
  #1293
Team Kamikaze's Avatar
PARTS for STI??????
Team Kamikaze is offline
Old 06-25-2006 | 05:06 AM
  #1294
Corse-R's Avatar
Originally Posted by Team Kamikaze
PARTS for STI??????
Yep... are available all the parts (crankshaft, conrod, P/S) for the STI with the same tolerances they used to build the engines.
Corse-R is offline
Old 06-25-2006 | 12:39 PM
  #1295
Racing4Evo's Avatar
Hi there guys,
Thanks in advance
Maybe you can have someone that is experienced with engines take a look at the fit between the conrod and crankpin. He should tell you if you need to replace the rod or not. I have a JP that has over 4 gallons without a rod change. Someone with a machining background checked it out and said the fit was practically like new.
Racing4Evo is offline
Old 06-25-2006 | 12:44 PM
  #1296
Corse-R's Avatar
Is not a matter of material wear, is purely a matter of fatigue of materials, after a break-in, the bronze bushing and the aluminium that surrounds the crank pin and the piston pin could be fatigued with micro cracks that can ruin the engine if the material fails.
On a .12 haven't found a conrod (if the engine has had a correct maintenance) that bronze bushing has been worn and needs to be changed. But sometimes sh*t happens and the conrod you saw in perfect shape, shits himself at the backstraight at full throttle and nothing is more scary that hearing your engine and thinking you were deaf suddenly because you don't hear the sound.
Corse-R is offline
Old 06-25-2006 | 12:48 PM
  #1297
Racing4Evo's Avatar
Maybe you are right, but I have full confidence in the opinion of the guy who checked it. His screenname on this forum is "Data".
Old 06-25-2006 | 01:05 PM
  #1298
Corse-R's Avatar
BTW: Data still computes up to 6th decimal?
Corse-R is offline
Old 06-26-2006 | 05:59 PM
  #1299
deviltires's Avatar
anyone know where i can get a crank for my evo 3 and will the sti crank work in the evo 3 .12
deviltires is offline
Old 06-26-2006 | 06:59 PM
  #1300
shiston's Avatar
for sirio parts try http://www.hobbybug.com/main.htm
shiston is offline
Old 06-26-2006 | 07:19 PM
  #1301
litespeed-dom's Avatar
Yes, it'll fit.
Just have your local Kyosho dealer order it from Kyosho America.
Dom
litespeed-dom is offline
Old 06-28-2006 | 04:29 AM
  #1302
HarKonnenD's Avatar
How is everyone liking the Sirio Evo 3? What code number or writing on the box will show that it is the Sirio Evo 3 and not the Evo 2? Also what plug would be great for using 30% as I run novarossi number 7 turbo in my 8th.
HarKonnenD is offline
Old 06-28-2006 | 04:35 AM
  #1303
Corse-R's Avatar
The EVO3 has the words Evo III engraved on their heatsink (look at the previous . I have an STI and with 16% nitro loves the Sirio #6 Cold, with 30%Nitro, surely you may want to use the #7 Cold.
You may take a look at the page 41 one post made by me where I show the several parts of a Evo III STi and look the cooling head (remove the STI and you have the EVO3 head).
Corse-R is offline
Old 06-28-2006 | 04:37 AM
  #1304
HarKonnenD's Avatar
Great! Thanks for the fast reply. I think on the box it said SpI or something T3...something like that. Just wanted to make sure it wasn't the Sirio Evo 2 Since they are sealed up. What did the lable say on the box?
Old 06-28-2006 | 08:50 AM
  #1305
Since you are in the U.S., the official part# on the box should say
S12T3ISTI
Dom
