Like Tree1Likes
Sirio engines thread
Old 12-15-2005 | 10:47 PM
  #1081
EdwardN's Avatar
on the note of turbo plugs.
On the Cristal park on the last couple of days is going some testing of motors and as I know all Novarossi glow plugs has the same problem-filament is OK (glowing and not really smashed0 but seal around central electrode is busted on most cases within 1 max 2 tanks of run. Only Sirio glow plugs can handle those testings. I was really surprized to see from plug to plug the same problem-seal after seal after seal-no one survived as I know.
But Sirio-no problem at all. It seems like (at list for me and guys who is making testing) Sirio plugs much more trustable then Novarossi
Edward
EdwardN is offline
Old 12-15-2005 | 10:51 PM
  #1082
wad's Avatar
wad
Is good that you said that, I lost the last race due to the glow-plug , it was a novarossi plug. I think that I need a change
wad is offline
Old 12-15-2005 | 10:56 PM
  #1083
jeffreylin's Avatar
Walter I got some Sirio plugs if you need them.
jeffreylin is offline
Old 12-15-2005 | 11:24 PM
  #1084
wad's Avatar
wad
Thanks Jeffrey, I'm on a little break now, but I will ask you as soon as I get back.
How was your surgery?
wad is offline
Old 12-16-2005 | 12:05 AM
  #1085
jeffreylin's Avatar
Worked out great. I will be able to race in a couple of weeks. Hoppfully there are races in January!!!
Old 12-16-2005 | 07:06 AM
  #1086
Default Non Sirio plugs for Sirio
Originally Posted by Racing4Evo
If you are talking about the plug numbers, they are very close from manufactuer to manufacturer. A Novarossi 6 would be equivalent to a OS 6 and so on...
Hi Guys,
Thanks for all the help.
Maybe you can tell me, if you not use Sirio plug for your .12 Sirio engine, what plug would you use?
Merry... Xmas...
fredgoh is offline
Old 12-16-2005 | 09:06 AM
  #1087
Racing4Evo's Avatar
Originally Posted by fredgoh
Hi Guys,
Merry... Xmas...
I almost always used a Novarossi 6F with my EVO 3. I would sometimes use a 7F.
Racing4Evo is offline
Old 12-22-2005 | 08:12 AM
  #1088
Grinder's Avatar
Where can one buy Sirio Evo 3 engines. They seem tough to get.
Grinder is offline
Old 12-22-2005 | 08:13 AM
  #1089
shouldnt you be working
Joe Chaplow is offline
Old 12-22-2005 | 09:22 AM
  #1090
Grinder's Avatar
What me??? JK, I am working..hard.
Grinder is offline
Old 12-22-2005 | 06:10 PM
  #1091
StormerHobbies has some threaded shaft models in stock..
Mark
markallen is offline
Old 12-24-2005 | 08:53 PM
  #1092
hey i got sirio .12 evo2 engine
i just broke my kyosho pipe i got from the kit so i need to buy a new pipe.
most ppl suggest me to buy sirio pipe as my engine will perform better with sirio pipe.
my question is, will it make any noticeable difference?
or any other pipe recommendation?
in my LHS sirio pipe is 40% more expensive than novarossi pipe
price is a matter for me
ickvanovs is offline
Old 12-24-2005 | 11:52 PM
  #1093
jeffreylin's Avatar
Sirio pipe is very very good--better than the Nova pipe IMHO. But if your LHS carries it you should get the Skyline pipe. It is one of the best .12 pipe out there if not the best. Price is reasonable as well.
Old 12-26-2005 | 06:01 AM
  #1094
skyline pipe?
hmm i havent seen one here
i will try asking in indonesian forum then
Old 12-26-2005 | 03:55 PM
  #1095
MadHacker's Avatar
Default Novarossi C6S Plug Substitute
Can anyone recommend a substitute for the Novarossi C6S plug? I would like to run an OS or McCoy plug (they are more available in my area). I will be using the plug in a Novarossi N528XSP engine.
Thanks,
MadHacker is offline
