Sirio engines thread
#1831
Originally Posted by rmdhawaii
Finally ran the .12 Evo3 STI today and even though I still had it running rich, it was silky smooth and very fast. I was running it with the Novarossi pipe and it spooled up really nicely. This is probably the best engine I've ever had in my car. Two more rich tanks and I can start leaning it.
have you tried running it with the sirio 2611 pipe?
#1832
Originally Posted by nikoskar
Dear All,
- After how many lt you change the rear bearing from .12, .21 On Road and .21 Off Road Sirio Engines?
.12 Sirio Evo 3(& STI)
.21 PR Pro & WCR(&STI if you know0
.21 Kanai(&STI)
- And the Conrod?
P.S.
I change mine PR Pro rear bearing every 4 lt of 25% Kyosho Fuel.
The conrod every 8lt
Thanks in advance.
Nick
.21 Kanai(&STI)
- And the Conrod?
P.S.
Thanks in advance.
Nick
i never change the rod.
has anyone ever measured the length of a new rod as opposed to a used rod to see if the rod has bent or lengthened?
#1833
Originally Posted by twiggy
i only change my bearings when they start making that 'rough' sound.
Did you measure the fuel lt after you heard that rough sound?(On .12 or .21)
After 8 lt at the conrod having a little space at the bottom where is the gold cicle.After that lt there is a breaking point at the gold cicle.
Nick
#1834
Then you will see something
Make sure that you wear a belt with your trousers
#1835
Twiggy,
Nick
Nick
it was a .12
#1836
glad you like it
- but having fun doing it.
#1837
I need to ask a ques, im using a Sirio Evo 1 .12 engine on a FW05rr. I know it needs to use a different type of starter box to accomodate its engine placement.
From the looks of my engine, can it support a roto-start? I dont suppose so right? There's nothing to poke the rotostart into. But the previous owner mentioned that he used a handheld starter. Is there a handheld starter other than sth similar to rotostart that i do not know of?
#1838
you can use a r/c plane handheld starter like this one http://www.modelflight.com.au/buy_mo.../p7260184a.jpg
but you have to replace the cup on the end with a rubber wheel.
#1839
in order to use a drill type starter you would need a pull start style crankshaft. Most starter boxes will allow you to move the motor and wheel from a parallel to a perpendicular position. For instance the Kyosho box will start both on road shaft and belt cars, as well as the big 1/8th off road buggy/truggy. Using a starter box will be much easier than anything
#1840
Dear All,
I have a Sirio PR Pro and i am facing problems with the carbulator.
Can you tell me what is the default turns of all the screws?(Middle, Low, High?)
Thanks in advance
Nick
p.s. Sorry for asking so many questions
Thanks in advance
Nick
#1845
Originally Posted by dameetz
Can somebody give me their clutch setting for low end torq? I m using RRR clutch with Sirio evo3 STI? How much is the end play supposed to be?
1Likes
