Like Tree1Likes
Sirio engines thread
Old 02-14-2007 | 04:50 AM
  #1861
dameetz's Avatar
Thanks a lot guys for all the tips. Today I tested it with a new clutch spring and adjusted the tension to 1.2 mm with 0.5mm end play, it is getting better but not enough yet, will try again tomorrow with different gearing as suggested. I try to explain in detail of my problem. When i punch the throttle to full, the engine roar for a micro second and when the clutch engage, the engine roars lower for about a second or two, there after it started to accelarate faster from mid to top.Compare to my osspeed, it just feel more linear during accelaration. I know this engine supposed to be very quick because I ve seen it during the worlds in Brisbane. I temp the engine it is around 120deg to 125deg. Will changing fuel to 25% helps as well? and will I need to add head shim?
dameetz is offline
Old 02-14-2007 | 08:32 AM
  #1862
nikoskar's Avatar
Originally Posted by Sirio2127
These settings are base settings for all sirio non sti 21 engines low end needle 5 and 1/2 turns from closed main or high speed needle 6 and 1/2 turns from closed and mid range is flush and then 1/2 a turn out. All these settings will get the engine running they are not factory settings more of a general starting setting if your carby gets all out of wack they should be a ritch carby setting as well. If not ritchen the main needle antill you get a ritch carby setting and then begin to retune your engine rembering that your engine will not hold a consistant tune antill it is at normal running temp around 90 to 120 dec C at those running temps your engine can be tuned corectly and it will hold a tune better as well. Hope that gives you some ware to start from. Also with the Sirio pr pro or pr pro evo2 and sti evo2 engines always use a number 7 turbo sirio glow plug with 25% nitro if you run higher nitro or in a very hot climet say air temps above 40 deg c you may need to go to a sirio 8t plug. Alway use a sirio or now a Rb zenon or matrix exhaust system for max paformance on and off road. Most improtant of all you must use a quality fuel that is vital to long engine life regardless of brand. Best Regards Jeremy.
Many thanka Jeremy.
Just i want...
You make me very happy...
nikoskar is offline
Old 02-15-2007 | 03:14 AM
  #1863
twiggy's Avatar
i would say your engine is overgeared.
definately try using 16/60 it will help your engine rev up faster out of corners.
twiggy is offline
Old 02-15-2007 | 03:45 AM
  #1864
Sirio2127's Avatar
Originally Posted by nikoskar
Many thanka Jeremy.
Just i want...
Any time Nikoskar, I enjoy shareing the info that i have about sirio engines. Best Regards Jeremy.
Sirio2127 is offline
Old 02-22-2007 | 04:48 AM
  #1865
Mcfly's Avatar
hi i hope someone can help, i am looking at a sirio 21 for my losi 8 and from what i can find the s21 bk kanai evo 2 sti is the best sirio(correct me if im wrong please), but after looking at the sirio website the sti has single adjustment carb, but the non sti engine says it has double adjustment carb. i thought the double adj would be the best, so is this a misprint or does the sti have the less adjustable carb?
Mcfly is offline
Old 02-22-2007 | 08:12 AM
  #1866
can anybody tell me where to get one of the evo3 sti's?
brianhatesnitro is offline
Old 02-22-2007 | 08:33 AM
  #1867
Tim Johnson's Avatar
If you are talking .21, they are not out yet in the states. If you are talking .12, check out shopkyosho.com, product from this website is shipped from a hobby shop closest to you that will have them in stock.
Tim Johnson is offline
Old 02-22-2007 | 08:58 AM
  #1868
I was looking for a discounted price, retail hurts. i found a place in austrailia for $261usd but shipping is probably rough.
SIRIOS12T3ISTI is the part # right?
Old 02-22-2007 | 05:43 PM
  #1869
HarKonnenD's Avatar
I planned on buying an STI 3 port after tuning some for some beginners and seeing how strong they are even on 20%. I have the MTX4 and was wondering what gear ratio should I use since they say these motors like taller ratios. I only have the skyline pipe to use with it so I'll give it a try.
HarKonnenD is offline
Old 02-22-2007 | 07:00 PM
  #1870
nino_pohan's Avatar
Hello, i have some problem to setting sirio engine .12 evo.. i dont have the manual. where can i get the manual? thanks
nino_pohan is offline
Old 02-25-2007 | 01:40 AM
  #1871
maskedrider's Avatar
hi guys, I had facing some leaking problem in my STi.
Had replace the the front bearing and two O-ring from the high-end needle.
but still facing the leaking problem. check the all ard the Crab. and found nothing wrong...inclued fuel tank and fuel line.
Oh yes, the leaking is actually somewhere around the carb which half below the Crab. Could it be some where else which is the common probelm ???
any advised pls from those who face the same problem..
maskedrider is offline
Old 02-26-2007 | 02:03 AM
  #1872
twiggy's Avatar
does it affect the performance of the engine?
is there more build up of fuel on the lsn side or the hsn side?
twiggy is offline
Old 02-26-2007 | 03:26 AM
  #1873
i can say the performance are quite slack but the ideling is ok...and this only run less then a tank... imaging if i ran the whole tank, it will be damn oily
here the picture.....
Old 02-26-2007 | 04:33 AM
  #1874
Z00M's Avatar
This is caused by the engine being too rich. When the engine is too rich, some extra oil/fuel is forced out through the front bearing and sprays off the flywheel onto the parts you see.
See your LHS or maybe have someone with more experience help you tune the motor. The reason it is 'slack' is also because it is too rich.
Z00M is offline
Old 02-26-2007 | 05:05 AM
  #1875
i had done a proper running in and been running quite a fews tank thru.
had change to a new front bearing too.... and still oily shown in the picture..
but funny thing is when i throttle on the box, can't see any leak at all , its only when i run a few lap back, its happen ...
maybe i lean and see hpws the result.
thanks for the help
