Sirio engines thread
#1711
Originally Posted by itchy b
Well, come on Rainer, times a wasting! Christmas is coming!
Get to breaking....... in your new baby!!
#1712
I just broke in this engine by running it at full throttle and fully opened up high needle. I dont know what u guys call this method.....i usually use this method for all my nitro engines and they work quite fine.
Whats the best recommended run in procedure for this small engine is it the same.... i have not yet driven the car around so i still have a chance to correct it if i have gone wrong.
Cheers...
Cheers...
#1713
Cheers...
Cheers...
http://www.cefx.net/tips/nitro/break-in/index.php
There are variations on this of course...
#1714
Originally Posted by rmdhawaii
Full-throttle break-in is generally known as the Josh Cyrul Method:
#1715
i would highly recommend everyone to heat the engine up 1st with a hair dryer or heat gun, then idle for 1 tank, let it completely cool, then idle for another tank. then hit the track, run slowly for each tank leaning 1/8 per tank. on the 7th tank, u are ready for race. then tune it properly. i found this method works the best for us coz we have just broke-in 2 engines last week, piston & linear were perfect, m breaking in mine today. haha.
as for the WOT, i only tried it once, but the outcome is rather bad. maybe i didn't heat it up 1st. and by heating it up, u dun have to force the flywheel with a testpen anymore.
#1716
Originally Posted by jag
I just want to say thanks to Sam (Team Kamikaze) for taking care of me on that Sirio pipe.
Thanks again Sam.
Jim
Thanks again Sam.
Jim
Sam
#1717
Heating up a new engine before the first time you start it, is a must.
WOT is a perfect methode, probably the best there is, but there are very different opinions about this issue.
Just pick what you think is the best for you.......
#1718
Has anyone ever tried grinding off those little ears on the crankcase to better accomodate conventional header springs? I did that with my newest Sirio and I hope to see an improvement in header spring life.
#1719
guys, has anybody used this vantage pipe in their sirio engine???
http://www.vantageracing.com/site/v2.../SE120L-17.jpg
any feedback on this pipe??? is this suitable for a 5 port engine???
am thinking of upgrading my pipe and i have a sirio evo3 T5 engine... would i be better off with this skyline inline pipe??? any feedback on this pipe when used on a 5 port engine???
http://www.skylinercracing.com/store/P_24.htm
thanks in advance...
#1720
This is the break in stand (aka bench) (http://www.rdlogics.com/cgi-bin/cate...i?item=15000):
And you'll need a airplane propeller starter to start the engine on it. Something like this (http://www.sullivanproducts.com/StartersContent.htm):
You don't have to use a break-in stand, but it is the preferred method for some. A lot of people just use their car. Most (if not all) manufacturer's instructions are for in car break-in.
I'm going to try the break-in stand method for my STI and my TZ when I replace the piston/sleeve. Should be interesting.
#1721
Follow this link. This has some great info on breaking in your engines.
#1722
1Likes
