Sirio engines thread
#1846
Originally Posted by dameetz
Can somebody give me their clutch setting for low end torq? I m using RRR clutch with Sirio evo3 STI? How much is the end play supposed to be?
#1848
Originally Posted by maskedrider
it's the S12T5STI which is 5port according to the Sirio site.
The STI 3 port will have more power than your Evo 2 ever had
Why do you need a % port STI
Have you got heaps of traction where you race?
#1849
Originally Posted by itchy b
A 3 port sti has loads of power!
a 3 and 5.
anyway, just got my 3port STI after mths of saving
TQ/ champion ......... here i come !!
#1850
thanks for sharing....just wanna to know the different between
a 3 and 5.
a 3 and 5.
As for sharing,
Any time bud
#1851
Originally Posted by nikoskar
Dear All,
I have a Sirio PR Pro and i am facing problems with the carbulator.
Can you tell me what is the default turns of all the screws?(Middle, Low, High?)
Thanks in advance
Nick
p.s. Sorry for asking so many questions
Thanks in advance
Nick
#1852
These settings are base settings for all sirio non sti 21 engines low end needle 5 and 1/2 turns from closed main or high speed needle 6 and 1/2 turns from closed and mid range is flush and then 1/2 a turn out. All these settings will get the engine running they are not factory settings more of a general starting setting if your carby gets all out of wack they should be a ritch carby setting as well. If not ritchen the main needle antill you get a ritch carby setting and then begin to retune your engine rembering that your engine will not hold a consistant tune antill it is at normal running temp around 90 to 120 dec C at those running temps your engine can be tuned corectly and it will hold a tune better as well. Hope that gives you some ware to start from. Also with the Sirio pr pro or pr pro evo2 and sti evo2 engines always use a number 7 turbo sirio glow plug with 25% nitro if you run higher nitro or in a very hot climet say air temps above 40 deg c you may need to go to a sirio 8t plug. Alway use a sirio or now a Rb zenon or matrix exhaust system for max paformance on and off road. Most improtant of all you must use a quality fuel that is vital to long engine life regardless of brand. Best Regards Jeremy.
#1853
Originally Posted by Racing4Evo
What are your clucth settings right now as well as your gearing. The Sirios love higher gearing than other engines.
#1855
don't use the red clutch shoe it will make you have to constantly keep adjusting the clutch bell gap as it is a sliping shoe and wares very quickly. stick with the gray shoe kyosho part #fmw 10 it may be a difrent number for the 3r evo clutch. What are you looking for? a punchy clutch feel or better axcelaration? If you want a puncher clutch feel take a 0.1mm shim off the thrust bearing side or "endplay" and put it to your shoe to clutch bell "gap" that way your not changing anthing just moving the clutch bell 0.1mm out from the shoe in outher words. Leave the 1mm spring tention and change the Gap to 0.5mm and the endplay leve the same 0.1mm. The outher option is to drop the first gear to 1 lower ratio than what you have now just one tooth on the spur may give the feel your looking for. You can also try to put more spring tention into the clutch but make shore its not slipping to much. Are you making good run time with your engine compared to outhers were you race? it may not be a clutch prob at all. I would do a litle testing and comparing with people who run the same chassis and the same or difrent engine and clutch settings. Regards Jeremy.
#1856
At the moment i m using 17/22t pinion and 59/56t spur. my setting right now is 1.0mm spring adjuster from the tip of the thread and shimming my inner bearing just enough to give it a gap for free rolling clutch bell and my end play gap when measuring using Kyosho pinion gear removal tool from the front is 0.4mm. I m also using the stock gray clutch shoe and s6 plug with 16% odonnel fuel and Sirio efra 2611 pipe. Somehow the engine just doesnt have enough low end torque however from mid to high end it is ballistic.
#1858
Thanks Sirio2127 and Jag, will try it again later today.
#1859
Dude, 17/59 is the tallest gearing you can run for first gear, try 17/61 and then let us know !
#1860
Originally Posted by jag
Try tightening the nut (spring adjuster) down to at least 1.2mm and give it 0.5mm of gap. If the spring is old, get a new one. It makes a big difference.
1Likes
