Like Tree1Likes
Sirio engines thread
Old 05-14-2009 | 03:57 AM
  #2596
barg's Avatar
Thanks for the update chadster....
I havent got a XXX yet. Ive been waiting for ver2 to come out.
Not that in a hurry at the moment. I have a couple of Evo4 club motors that will keep me going for a while.
Hope to get the XXX for the QLD titles though.
barg is offline
Old 05-24-2009 | 02:36 AM
  #2597
Default sleeve/Piston for Sirio s21s or S21r
Anyone know where I can get a replacement sleve/piston for an old s21r or s21s, from what I can tell these are both the same engine, one aimed at on-road the other for off-road.
I've acquired one cheaply and has very little compression, and turns over way to eaisly, suspect it has many miles under it's belt.
Cheers
Francois
farsonic is offline
Old 05-24-2009 | 05:11 AM
  #2598
keavze's Avatar
Default shims for 25%
hi guys,
my .12 STI4 got stock of 0.3mm of shims; so i presume it's for 16%?
how much shims should it have to use 25%?
keavze is offline
Old 05-27-2009 | 08:48 PM
  #2599
Need help for my Sirio EVO3.
I have problem keep running engine after I unplug glow plus ignition. After I unplug it, engine just stop running. Can anyone help with this? I am running 16% nitro and 15% oil fuel. Thanks
chavoo is offline
Old 05-27-2009 | 09:45 PM
  #2600
NitroWD's Avatar
check yr plug 1st...make sure it's ok else just try new plug.
you're using sirio S6 plug?
NitroWD is offline
Old 05-27-2009 | 11:29 PM
  #2601
Yes, I changed plugs. I have used Turbo Plug no. 6 and 7. Finally it runs with No. 6, but it does not stay idle. When turn to idle, engine just do not like it. Then wind down and stop. So, I got no idea how this happen.
chavoo is offline
Old 05-28-2009 | 12:20 AM
  #2602
NitroWD's Avatar
for 16%nitro, s6 plug better.
check yr throttle linkages, make sure it's not closing the idle gap when u release throttle or braking.
if not set a bigger idle gap so that it can idle and retune from there...
NitroWD is offline
Old 05-28-2009 | 12:47 AM
  #2603
M7H's Avatar
M7H
I think 15% oil is also a bit to much....
M7H is offline
Old 05-28-2009 | 01:31 AM
  #2604
blown sv's Avatar
if it idles with the glow warmer on and stops when you take it off , it is to rich on the bottom end , if its very rich on the bottom it causes it to stop due to way to much fuel
blown sv is offline
Old 05-28-2009 | 01:59 AM
  #2605
I adjusted low speed needle to lean it, but the same thing happen. Any other things cause this problem?
chavoo is offline
Old 05-28-2009 | 06:22 AM
  #2606
Default idle
Turn the idle screw in . To set the lowspeed rev it a few seconds and when it comes to idle if it drops rpm lean the lowspeed. If after reving a few seconds the rpm comes up at idle it's to lean. Make sure the gap on the slide is not too small or it will be impossible to get right. Hope this helps.
latemodel13 is offline
Old 05-29-2009 | 12:53 AM
  #2607
blown sv's Avatar
lots of causes, how used is it?
blown sv is offline
Old 05-29-2009 | 05:20 AM
  #2608
Finally, I got it run. I set idle first and then adjust low speed needle. Thanks for everyone's help.
chavoo is offline
Old 05-30-2009 | 12:08 AM
  #2609
keavze's Avatar
Default rich but high temp? (.12 Evo4 STI)
hi guys,
is it possible for the engine to run hot (about 280-290F) but still rich (piston and button head still shiny wet)? engine power seems ok but not that REALLY fast yet...
air temp about 80F and humidity about 70%...
what could cause the above scenario?
i've checked my clutch and it's not slipping and my car's transmission seems ok, no binding...
keavze is offline
Old 07-01-2009 | 05:26 PM
  #2610
barg's Avatar
This is what ive been waiting for..... Article from Red RC.
Sirio have sent us the first picture of their latest .12 engine called the XXX V. The latest evolution of their successful XXX engine, it features an updated crankcase with better strength, providing you the best performance, durability and fuel economy. Ceramic bearings and careful construction further ensure a reliable and powerful motor. Available from Monday July 6th.
barg is offline
