Like Tree1Likes
Sirio engines thread
Old 02-01-2009 | 03:07 AM
  #2521
jameslow's Avatar
skyline pipe should not be a bad choice... i have try it on sirio evo 2 and is running gd.. so i think sti4 should not be a problem too!!! hehe!
jameslow is offline
Old 02-01-2009 | 03:45 AM
  #2522
keavze's Avatar
skyline wont be a 'problem' for any engines in fact but i want to know how far/bad is it compared with 2611 as 2611 is deemed the best pipe for sirio.
also will 5 or 6 fins manifold be more suitable for the sti4 (if using skyline)?
keavze is offline
Old 02-01-2009 | 05:36 AM
  #2523
auggy79's Avatar
I had tried the Skyline with the Evo 3 Sti before and the power was significantly lesser as compared to the 2611. Have not tried with Evo 4 before but my guess is that it will be with around the same results......
Sirio Engine requires a longer pipe as it is very good on high end revs but a bit flat on the bottom punch so the 2611 compensates for this
Hope this helps
auggy79 is offline
Old 02-01-2009 | 07:15 AM
  #2524
auggy79's Avatar
By the way does anyone know where can I purchase a Sirio XXX Conrod?
auggy79 is offline
Old 02-01-2009 | 02:45 PM
  #2525
Default Werks Team Line B7
anyone know what the factory setting are for a Werks Racing Team Line B7 Pro .21?
8ight-t Driver is offline
Old 02-01-2009 | 04:09 PM
  #2526
Osiris 75's Avatar
What would cause the Sirio EVO 4 to continually stall at the end of the staight, with temps at 240?
Osiris 75 is offline
Old 02-01-2009 | 04:34 PM
  #2527
NitroWD's Avatar
the moment when you let off the gas or still at full throttle?
if it's when you're still at full throttle; you're too lean, gotta rich it.
if it's when you've let off the gas, you can try to bump up the idle abit.
(also check the radio epa on the brake/throttle)
NitroWD is offline
Old 02-03-2009 | 08:13 AM
  #2528
abul's Avatar
would anyone agree with me that sirio engine need to be run a liitle bit high on temperature then nova base engine?...any comment?...
abul is offline
Old 02-03-2009 | 09:54 AM
  #2529
Nitro-Racer*'s Avatar
i am pretty sure that its the oposite
Nitro-Racer* is offline
Old 02-03-2009 | 10:06 AM
  #2530
impalabob64's Avatar
Default No
Here in Florida ,they need to run alittle on the rich side
impalabob64 is offline
Old 02-03-2009 | 12:47 PM
  #2531
Speyederjedi's Avatar
Kemp,
Your idle needle is probably set to low. With my Sirio it idles great when cool but once the temp gets up a bit over 225 the idle will drop down a bit and sometimes the engine will die out so now I run with a bit of a higher idle when cold and once it gets up to temp its fine. Also, what plug are you running? With the cooler temps we've been having a 6 or 7 plug is a bit to cool and the engine may have trouble staying lit at idle. You can drop a shim or go to a hotter plug. I went to a #5 plug and haven't had a problem.
Regards,
Daniel
AKA:Speyederjedi
Speyederjedi is offline
Old 02-03-2009 | 12:53 PM
  #2532
Yep, I'd have to agree, here Sa Antonio, Texas a few of us are running the Evo 4 Sti and it's a bit like some of the Piccos I've had.... Likes to be fat on the bottom end.
Regards,
Speyederjedi
Old 02-03-2009 | 03:54 PM
  #2533
GMartinez's Avatar
Default Sirio .12 items for sale
I have a couple of spare parts for sale pm me with your needs
sirio spring nut deal pending
sirio clutch spring deal pending
sirio carb restictor 5.5
sirio thrust beering guide deal pending
4-blue clutch shoes deal pending
2-red deal pending
2 yellow deal pending
sirio carb return spring
2-siiro exhuast ring
2-sirio power clutch weights deal pending
1-sirio power clutch disk deal pending
1-sirio .12 head shims
2-sirio evo4 conrods
1-sirio evo4 piston pin
GMartinez is offline
Old 02-10-2009 | 04:57 AM
  #2534
NitroWD's Avatar
Default sirio using picco pipes?
anyone tried using their sti with picco pipes like 2607?
NitroWD is offline
Old 02-14-2009 | 12:12 AM
  #2535
i was wondering what the new xxx is like? is it good on wear and tear,performance,tuning etc. cheers
elche_83 is offline
