Houstons Engine Service H.E.S.
#7547
#7548
Ok, maybe in a extreme nova818 vid, but not with a bearing tool....
Just saying...
#7549
I know nothing of nova bearings, but I do know hardend steel, and unless these races are not hardend, I have to call BS. Try scaring a hardend piece of steel with a blund object, such as a ball bearing.... NEVER HAPPEN!!!!
Just saying...
Just saying...
It's got nothing to do with hardened steel. It's all about crushing the inner part of the bearing between the tool and the inside of the motor where the inner race seats. Kinda like if I put your head in vice and started turning the handle clockwise til your brains spill....
#7550
Am just gonna throw my 2 cents in, Your original bearing was probably good. That seems a little pre mature for a bearing in a werks to go bad. Not saying it isn't possible, but to say a bearing is bad cause it's leaking in the first gallon would be a wrong call to me, cause it still will be rich....
#7551
Nice way of putting it tho....lol
#7552
Just saying...
Just saying...
I used to work on race engines and diesel engines, we had special bearing tools for special bearings, some had lips to compensate when a bearing was off set such as the Nova bearing. This again was with race engines and diesel engines, these engines come no where near the rpm's of our rc engines. If it was important on a 10,000 rpm max race engine, what do you think about a 40,000 rpm engine is gonna be like?
#7553
At 2 gallons, I fully agree.... He stated, about a gallon, which, most guys would still be on the rich side.....
#7554
I did a lil work on mine
#7555
Monty knows his stuff, I wouldn't ever disagree with him even if he didn't give a reason for something. But if you look at what he said the inner race is out .3mm that means the bearing is not flat, so if you use a flat bearing tool you would be putting it in a bind, thus causing a flat spot on a bearing ball or two depending on which way the inner race moved because of the pressure of the bearing tool.
#7556
#7557
At 2 gallons I changed my flywheel and noticed it, so more than likely at about a gallon mine was already loose or off the front bearing. I am pretty sure I didn't stop and the front seal just happened to come off when I pulled my flywheel off. Even if you are on the rich side the bearing can go bad. Just because someone may or may not be on the rich side shouldn't really affect the front bearing from going bad. At least in my mind I don't see the correlation of a rich tune = front bearing being bad
#7558
#7559
22Likes
