Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 05-25-2012 | 03:46 PM
  #6661
houston's Avatar
Originally Posted by Fd2k
My friend is having a barbecue in a park and we planning on running our buggies. But the smell of nitro Might bother ppl so we thinking of buying Parma nitro speed scent. They come in different scent like cherry. I think if we used it, it won't bother ppl as much. My question is will the nitro scent do any harm to our Nova or Werks .21 engines?
http://www.shopatron.com/products/ca...1.6091.0.0.0.0
The burning of the "smelly jelly" does leave residue inside the engine but its not gonna ruin it , all good
houston is offline
Old 05-25-2012 | 06:33 PM
  #6662
houston's Avatar
My personal method which I use is as follows
Mount engine in car , preheat engine using competition heat engine warmer (easiest most prefered method) , prime engine by blowing into the pressure line and holding carburetor open until fuel has reached all the way into the crank case .
Preheat to a temp of at least 170° fahrenheit , start engine , you might have to keep it idled up a lil at first until engine settles into a smooth idle (hotter plug helps with break in). Monitor temps frequently , if temps start climbing higher unplug comp heat unit , use low speed needle and idle screw adjustment to get engine to idle between 190°-210° . Let idle for 5 min then shut down , leave head covered while idling , repeat this process three times , preheat , idle , shut off , cool down with piston out of the pinch area or BDC .
Next step is similar , preheat , start engine , idle for a minute or so , make sure carb is fairly close to "in balance" but hsn fairly rich lsn 2-3 hrs rich of a race tune and run car on the ground for approx. 10 min. , you will have to tune engine so it stays at 190°-210° while running the car around in a parking lot with the body on (do not over rev, use 40'-50' lengths so as not to gain too many rpm's) , no head cover . Repeat this process 3 times - preheat , run car on ground for 10 min., shut off , cool down with piston at bdc .
Next step is same as on ground intervals but this time do 30 min intervals on the ground with the body on no head cover . You can start to drive car on track for this but do not over lean engine , do not over rev!!!!!! , keep temps between 190-210F and do not "blip" the throttle , all these steps are important .
hope this helps ,
Monty Houston
houston is offline
Old 05-25-2012 | 07:32 PM
  #6663
hookem34's Avatar
R/C Tech Elite Member
hope this helps ,
Monty Houston
Stickied this to my ever growing engine file. Thanks for putting words to paper (errrrr digital paper) Monty!
hookem34 is offline
Old 05-26-2012 | 01:24 PM
  #6664
hope this helps ,
Monty Houston
So is this your break in procedure or an answer to another post?
Thanks Bill
1airborne is offline
Old 05-26-2012 | 09:14 PM
  #6665
houston's Avatar
Thanks Bill
when i do a full in car break in , this is the method
houston is offline
Old 05-26-2012 | 11:24 PM
  #6666
When you say "no head cover" do you mean, no heater cover on the head?
Thanks 1airborne
Old 05-27-2012 | 06:03 AM
  #6667
houston's Avatar
Thanks 1airborne
Yes sir
houston is offline
Old 05-27-2012 | 01:33 PM
  #6668
Yes sir
Thanks, your the best engine guy around. Both of my engines are running great. I am going into my 8th gallon on the first one, and took 4th in a recent race with it.
thanks again.
1airborne
Old 05-27-2012 | 02:48 PM
  #6669
houston's Avatar
thanks again.
1airborne
8GALLONS???? very nice!!!
i am very glad you are happy with your engines bro , keep me updated , i love to hear your guys' stories, good , bad or ugly im here to help ya
houston is offline
Old 05-28-2012 | 02:55 PM
  #6670
Hope the engine got to you in one piece Monty! I know you just got it late last week, just curious if you'd even had a chance to give it a once over to see if there was anything that jumped out at you right off the bat?
Definitely not pushing or anything, just curious
KSimmonds is offline
Old 05-28-2012 | 09:47 PM
  #6671
houston's Avatar
Done , call ya tmrw
houston is offline
Old 05-29-2012 | 07:33 AM
  #6672
Done , call ya tmrw
Sounds good, thanks!
Old 05-30-2012 | 09:37 AM
  #6673
As most of you probably already know, Monty is first rate when it comes to customer service! I'd just like to thank him for going above and beyond with an issue I was having on my plus 4. Thank you Monty!
Old 05-30-2012 | 05:33 PM
  #6674
houston's Avatar
its just the way i roll Kyle
i try to support the products you guys choose to get from me man , its the way i would expect to get treated so i do it
houston is offline
Old 05-30-2012 | 08:39 PM
  #6675
Nitro$junkie's Avatar
$215 for a plus 4 that for real? cant pass up on that price looks like im gonna have to scarp the P5 and just get that
i know this been covered a ton of times but 9901 or 2096 in buggy cant decide
Nitro$junkie is offline
