Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-23-2012 | 10:51 AM
  #6346
kgombe's Avatar
Originally Posted by FUSIONX AUS/NZ
A few of us here are talking about and are 99% sure we will be coming over for next years DNC race , I can not wait!
Dave
thats cool man...
kgombe is offline
Old 03-24-2012 | 07:25 AM
  #6347
houston's Avatar
I wanna go down there
They'd probably give ya a pretty hard time flying with rc gear internationally
houston is offline
Old 03-24-2012 | 11:25 PM
  #6348
jnorwood_losi's Avatar
Default Bonito Help.
Monty I need a little help.
I have a new Bonito with about a gallon and a half through it and I was at the track Fri and it lost its mechanical pinch finally. I always at very least heat it with a comp heat before running and if at rest for more than 20-30 min will heat again.
I was having allot of flame out toward the end of the day, even at temps (avg about 220-235 if I stopped for a few min or refueled I would blow it out well and all making sure it was at temp but would pull on the track and flame out, would keep happening several times but once I DID get it going it would run like a CHAMP. Any advise??? Its the bonito with ceramic rear, I have not tore it apart at all since I have had it (a month)
THANKS
Jason
jnorwood_losi is offline
Old 03-24-2012 | 11:43 PM
  #6349
houston's Avatar
THANKS
Jason
going off your explanation which doesnt really elude to how the tune is the first thing i would say is clutch and/or clutchbell bearings Jason
check all your exterior components relating to the engine running properly then lmk whats up Jason
hope this helps
get back to me with pipe/plug/clutch/needle settings/fuel/car/etc. etc.
houston is offline
Old 03-25-2012 | 08:53 AM
  #6350
Sorry I was a little lite of info. 8t2.0 Bonito/41021 manifold/9901pipe/C6TGC plug/Byrons 2 gen Pro 30-9%/TLR prebuilt Alum clutch (green on plastic gold on Alum)/ HSN BAIRLY in from flush/LSN flush to 1-2 hour out from flush/again factory shims cause have not pulled apart/DC metro area(dont know altitude)
The clutch DID lock up on me on this day, the big bearing was ON THERE and I mean ON there, shoes looked ok so replaced bearings and after my first 2 tanks went back to the flame outs. Only happened (even though up to temps) when it rested for a few min or refueled, would have to start SEVERAL times, blow out HARD and get it going and it would go back to running like a scalded dog LOVE it running like that.
I REALLY appreciate your help and advise!!!!! you are +1000* when it comes to helping people and that is just awesome!!
Thanks Again
Old 03-25-2012 | 09:11 AM
  #6351
houston's Avatar
Thanks Again
Outside temps? engine temp?
Your probly just the classic leaner on top , too rich on the bottom
check out the burnard derand tuning video in the tuning bible bro
richen top a little , get engine fully up to temp , lean lsn until idle is consistent lower idle until you get a nice comfortable idle , not too low , go out on the track and finish hsn dialing in
Also if its colder out put a c5tgc in it
houston is offline
Old 03-26-2012 | 08:01 AM
  #6352
Clete Landefeld's Avatar
Default Houston, we have a problem
Mont,
I need a motor rebuild, a rod and a little TLC.. Can you please shoot me a pm and let me know a time when you would like me to drop it off!...
Nitro on road is starting up in just a couple of weeks!... you gonna come race GT with us?
Cheers,
Clete Landefeld
Clete Landefeld is offline
Old 03-26-2012 | 09:30 AM
  #6353
Hello- I was wondering when you may expect to have some more Novarossi 4btt's in stock? Thanks
nrm1977 is offline
Old 03-26-2012 | 10:07 AM
  #6354
revo61's Avatar
Can't wait for new X3 to get here. This is my home track New and expanded layout.
http://www.youtube.com/watch?v=t8m3K2jlixI
revo61 is offline
Old 03-26-2012 | 11:07 AM
  #6355
houston's Avatar
Originally Posted by Clete Landefeld
Mont,
Cheers,
Clete Landefeld
Come on over
Whos got a gt car for me?
houston is offline
Old 03-26-2012 | 11:08 AM
  #6356
houston's Avatar
Got one
houston is offline
Old 03-26-2012 | 01:32 PM
  #6357
Oh nice! You're site says your out of stock. If the engine is still available I would like to purchase it plus the silicone filled crank mod. Oh is the btt with the rear ceramic bearing? Lmk thanks.
nrm1977 is offline
Old 03-26-2012 | 01:57 PM
  #6358
houston's Avatar
its btta atm but it will be a btt in a matter of minutes or btts if you prefer
switching bearings is a matter of minutes for me
houston is offline
Old 03-26-2012 | 02:14 PM
  #6359
Awesome, just bought the $345.00 one! Which pipe and header do I need? Med bumpy track in Midwest. Not to open of a track....thanks!
nrm1977 is offline
Old 03-26-2012 | 02:43 PM
  #6360
houston's Avatar
most torque
9853ss/41021 , smooths out with 41005 , 41001 or 41019
2084ss/41021 (same as above)
2096ss/41021 (very nice combo!!)
9901ss/41021 (most preferred) bonito use 9901ss/41021 0r 41020
9886/41021 violent powerband and most top
least torque most rpm
mugen header equivalent 41021=41029 , 41020=41030
lmk if you need anything else
recommend c5tgc for up to 75-85° and c6tgc above these temps
hope this helps
houston is offline
