Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 02-20-2011 | 12:08 PM
  #4786
teeforb's Avatar
Originally Posted by houston
i am not sure who carries byrons in your area
amain hobbies has both of those items and their prices are usually pretty competitive ?
whats your zipcode and i will check for ya
92128
Thx
teeforb is offline
Old 02-20-2011 | 12:12 PM
  #4787
houston's Avatar
Originally Posted by teeforb
92128
Thx
byrons fuel dealers near 92128
and i gave you some detailed instructions on how to break in your novarossi based engine
houston is offline
Old 02-20-2011 | 12:24 PM
  #4788
teeforb's Avatar
Sweet! Thanks.
Yes, please on the instructions for the break in. Also tips on basic tuning.
teeforb is offline
Old 02-20-2011 | 01:00 PM
  #4789
teeforb's Avatar
Not looking good on the fuel the places I called don't have what I'm looking for and they can't order it because they need a 36 gallon minimum. Amain has a $40 haz fee per case. This sucks.
teeforb is offline
Old 02-20-2011 | 01:07 PM
  #4790
houston's Avatar
pro driver will work if you find some lube booster to add into it , 2.5 cups (cups that come with the lube booster) per gallon
amain is only 140$ per case
houston is offline
Old 02-20-2011 | 01:10 PM
  #4791
houston's Avatar
main thing is DO NOT use a full synthetic oil fuel to break in your engine !!!
houston is offline
Old 02-20-2011 | 01:39 PM
  #4792
teeforb's Avatar
im figuring it out!
teeforb is offline
Old 02-20-2011 | 02:38 PM
  #4793
teeforb's Avatar
Hey Monty, much love on the data! A few questions on terminology..
1) comp heat?
2) primed the system?
3) Cleaning the engine out?
4) heat cover?
5) heat cycles
6) hest cycles
7) air filter media
that would be my recommendations
and DO NOT break the engine in blubbering rich , thats even worse then grossly over lean , well almost
heat engine to 190-210° , i prefer comp heat , start it after you have primed the system by opening carb and blowing into the exhaust pressure line until no more air bubbles go through line , dont be afraid to rev it up a lil , keep it running , you will have to lean the needles a little and turn the idle up a touch , use a quality temp probe such as exergen brand (important) tune as to maintain a constant temp between 190-210° , unplug comp heat and let idle for 5 min , engine will be a little erratic at first but will settle in after a bit , clear the engine out every minute or so .
repeat this process three times on the bench with head covered , make to sure to pull head cover off during cool downs , place piston in a free movement area (some refer to this as BDC)
after 3 x 5 min heat cycles do 3 x 10min heat cycles on the ground in the car at 190-210° , head uncovered (unless ambient temp is below 50°) and run around gently , dont baby it but do not rod on it , above all refrain from blipping the throttle as it is referred to .
after 3 x 10 min heat cycles do 3 x 30 min. hest cycles , the last one of these can even be done on the track but remember to keep a conservative tune , do not rod the engine all the way down the straights , check temps frequently .
from most novarossi engines i would not expect miracles within the first gallon of fuel but the engine will perform well enough to race with , at some point the engine will change tune and go really rich on ya and tune will keep changing for a period of 4-5 tanks of fuel , i call this "dropping the nuts"
when you take the time to take care of your novarossi based engine it will provide you with a long life of trouble free running !!!
remember to make sure your air filter is always up to snuff!!!!
there are a few companies that sell air filter media that i wouldnt use if they paid me , one great bargain and excellent material is answer rc , great filter media , when used in conjuction with the awesome kyosho air filter oil , your filters will stay dirt free and protect your valuable engine !!!
happy motorin ',
Monty
teeforb is offline
Old 02-20-2011 | 04:44 PM
  #4794
houston's Avatar
1) comp heat? Competition heat engine block warmer 120v version
2) primed the system? Blow into exhaust pressure line that would normally hook up to the exhaust pressure nipple while holding the carburetor open until fuel enters the carb with no air bubbles
3) Cleaning the engine out? Rev engine up enough to clean all the excess oil from the engine/exhaust
4) heat cover? Head cover
5) heat cycles heating and cooling of the engine
6) hest cycles fat fingers , sorry
7) air filter media the sponge that the filter is made from
Hope this helps teeforb
houston is offline
Old 02-20-2011 | 05:01 PM
  #4795
teeforb's Avatar
Gotcha! Some stuff i kinda knew, just didn't want to make any bad assumptions...
teeforb is offline
Old 02-20-2011 | 05:48 PM
  #4796
houston's Avatar
the only stupid question is the one you never queried?
houston is offline
Old 02-20-2011 | 06:31 PM
  #4797
rotarynut's Avatar
Questions?? apparel
Monty, where can I find Novarossi apparel? Novarossi USA and Desoto racing don't have hardly anything,what's up with that?
rotarynut is offline
Old 02-20-2011 | 07:22 PM
  #4798
mHOUPS's Avatar
Monty, I have two Nova's I'm shipping out on Tuesday. Just wondering, should I ship them or give them to you at the Nitro Challenge?
mHOUPS is offline
Old 02-20-2011 | 07:31 PM
  #4799
houston's Avatar
since i will be pretty maxed out on cargo at the nitro challenge probably ship them would be best
houston is offline
Old 02-20-2011 | 07:32 PM
  #4800
houston's Avatar
i am going to find out more about that this weekend , also gonna grill jim on the fusion X line , stickers , shirts , hats and what not
i know in an effort to keep costs as low as possible it does not work but we shall see
houston is offline
