Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 09-02-2010 | 04:36 PM
  #3916
newuserlosi8t's Avatar
is there a turbo head conversion for the novarossi n21r limited ,is there parts and where
newuserlosi8t is offline
Old 09-02-2010 | 05:04 PM
  #3917
houston's Avatar
N21r takes 28002 turbo headbutton
houston is offline
Old 09-02-2010 | 05:20 PM
  #3918
and where are parts avalible thanks in advance
Old 09-02-2010 | 07:02 PM
  #3919
rotarynut's Avatar
Right here!http://www.houstonsengineservice.com...d76aa78977395b
rotarynut is offline
Old 09-02-2010 | 08:56 PM
  #3920
Originally Posted by rotarynut
nice thanks man
Old 09-03-2010 | 01:28 AM
  #3921
Lonestar's Avatar
Monty,
can you comment on the "sport" line of odo plugs? the reds purples and pink with green dot ones How different are they from the usual "race" plugs a la 77, 97, 100 and such?
Thanks,
Paul
Lonestar is offline
Old 09-03-2010 | 06:31 AM
  #3922
houston's Avatar
Originally Posted by Lonestar
Monty,
Thanks,
Paul
I would if I have tried them paul , I have payed attention to them but am not gonna carry them as the other plugs seem to work very well . I don't think they are made in the same factory though so that could be a determining factor on why I Don't use them even though I am sure they are fine
houston is offline
Old 09-03-2010 | 07:34 AM
  #3923
Lonestar's Avatar
Fair - thanks
Lonestar is offline
Old 09-03-2010 | 08:27 PM
  #3924
air8's Avatar
Originally Posted by kgombe
what restrictor did you use
Sorry, I used the 7.5mm. For some reason I left the 8.0's at home.
air8 is offline
Old 09-03-2010 | 08:47 PM
  #3925
kgombe's Avatar
ok thx.. that what i was going to use this weekend
kgombe is offline
Old 09-04-2010 | 03:23 PM
  #3926
air8's Avatar
I really wish I could've finished that race. I would like to know the mileage with the 7.5mm. I'll put the 8.0 for my next race. I must drive efficiently cause my +4 can pit at 12 minutes on a regular basis. AT the Futaba challenge the mileage was down but I found the front bearing to be leaking and I didn't find it till I tried tune the engine for 20 minutes. I used to use a GRP .21 Tuned in my truggy and it too would go 11 minute pit stops every....single....time. It was awesome.
So I have no doubts the FMS will go 10 minutes. I just want to verify it. LOL.
air8 is offline
Old 09-05-2010 | 07:57 PM
  #3927
From: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Default Birthday greeting
Happy birthday Monty
Ray
RayA is offline
Old 09-05-2010 | 09:01 PM
  #3928
do you offer a break in service?
C.Harper is offline
Old 09-05-2010 | 11:58 PM
  #3929
KWT-NITRO's Avatar
yes he does,
he uses Byron gen 2 fuel and break in the engine using the heat cycle method on a real car and running on a real track for about 1/2 a gallon and NOT on a bench
hope this helps
cheers
Ali
KWT-NITRO is offline
Old 09-06-2010 | 01:31 AM
  #3930
Lonestar's Avatar
Just in case anyone is still interested in my N21R trials and tribulations.
I tried the 9901 + 41030 and 41021 (sorry, won't buy 005 header...) again this weekend, to no avail. The mill simply refuses to rev properly, and is a low-rpm dog, no matter how hard and what I try. When cranking out max HP (ie not much) it will easily temp 270F on my newly received exergen (hurray!) and keep climbing, if I richen it it just sounds wrong and is a turd in the straight. There is no way any different header could add that much low- or hi-rpm HP, so I will simply conclude that 9901+N21R is anything but the hot ticket at least on my mill.
During the same practice session, I also swapped pipes in 3mn back to the "standard" 086HS, using same fuel, same plug, same filter, same weather, same clutch, just swapping exhausts - this is litterally night and day, suddenly the engine lives, is stable, not overheating, not stalling, it's nice nice nice, a real $135 treat
what, again, is stunning me is that my buddy's N21BF is a screamer with 9901+41030 so either NR's QA has some serious slack in their process, or there is more changes from the N21BF to N21R than sees the eye...
I'm done with testing now Overall I'm happy with the 086HS, so it's now and forever my N21R's official exhaust. Screw runtime, I'd rather have the car drive like it should than -maybe- get 10mn+ refills and not be able to clear the jumps...
N21R + 086HS = Nice little <$200 combo
Paul
Lonestar is offline
