Houstons Engine Service H.E.S.
#2677
http://www.amainhobbies.com/product_...-21-50-cu-in-1
#2678
Monty told me the OD 77 or the 100. He favors the 100.
The only saving grace is that you don't have any altitude mixed in there
#2679
Will the C5T nova plugs work alright in my +4C. I plan on getting the ODO's, but I got these at a steal.
#2680
#2681
Houston will the 15007-T crank fit in my Crono RS5? Do you know what the differences between the P5 and RS5? If I put a turbo head button on it. How should it be shimmed? Thanks!
PS: It would be nice to surprise people. When your passing people with what looks like a older engine. Makes me smile
#2682
there is a little different porting in the rs5 as far as sizes of the vertical transfer ports and there are "bypass" ports on the rs5 5+2 configuration
.80mm for shimming , it should have .70mm on it now
part# 28002 is what you are looking for
#2684
Yes, the RS5 is an older engine, but they were the best engines i ever had util i got some very spesial OS v-specs, you could not buy over the counter... Now, my favorite for long tracks is still the OS, but for shorter echnical tracks is the +4.
If i could get the RS5 psiton and sleeves, i defenatly would blow back some life into my Rs5`s engies.
BTW, if you are able to, get the new Nova +4 carb and put it on your RS5, and i`ll bet you get alot better runtime out of it..
22Likes
. Also, sending PM.
