Like Tree2Likes
RB Concept Engine Thread..
Old 03-23-2013 | 02:28 AM
  #3031
http://www.amainhobbies.com/product_...ine-Turbo-Plug
Herrsavage is offline
Old 03-27-2013 | 08:59 AM
  #3032
Iv got a bxr and finished running in. Cleaned it, then noticed the front
Bearing is loose!! Same with my other buddy same engin. Any body can advise. Sad and disappointed
graceku is offline
Old 03-27-2013 | 09:17 AM
  #3033
Sorry , when I meant loose
I can pop the front bearing in and out of the crank case! with just using fingers
Why ??? Help!!
graceku is offline
Old 03-27-2013 | 03:45 PM
  #3034
jk1152's Avatar
Why ??? Help!!
The bearing is not falling out right? I think you mean the inner race moves when you move the crank? You should "pull" the crank all the way out, and move that inner racing all the way "back" towards the backplate as you can when you put the cone on. This way when you tighten up the flywheel it will not really move back and forth.
jk1152 is offline
Old 03-27-2013 | 04:25 PM
  #3035
What is happening is, the front bearing just fall out!!! Or I can just push it back in to the crank case!!! just wth my fingers
Don't even have to use a bearing puller
Is it a manufacturer defect??
graceku is offline
Old 03-27-2013 | 04:54 PM
  #3036
I would contact A Main Hobbies as they are the importer for the RB engine now and talk to them. It isn't normal but I can't say it is mfg defect. It would sound like it though. Best of Luck!
Chris Reilly is offline
Old 03-27-2013 | 07:03 PM
  #3037
I sure think it the manufacturer defect. Not 1 engin but 2 !!
Any help, who or how to contact at rb? Big disappointment for a big. And renounce company!! Otherwise the engine is great
I not frm the USA. I frm Asia
graceku is offline
Old 03-27-2013 | 07:25 PM
  #3038
Go to RB Products page and send them a email or call them and see what happens.
http://www.rbproducts.com/mainEn.php...page=contactEn
Old 03-27-2013 | 08:55 PM
  #3039
Thanks for all the help and info!! I,'ll keep u guys up dated
I 've have vdo on it and forward with this enquiry (complain)
graceku is offline
Old 03-29-2013 | 07:16 AM
  #3040
Still no reply frm rb
Any other help I can look for?
Earth calling rb!!??
Eric allsa!! Of rb??
Depressing???
graceku is offline
Old 03-29-2013 | 08:07 AM
  #3041
bigjayjay1's Avatar
Normally the bearing size is lazer etched on the side of the bearing race.. What is it?
bigjayjay1 is offline
Old 03-29-2013 | 04:47 PM
  #3042
The bxr just runed in, took it apart,
Useing the hudy bearing puller. As I extracting the front bearing, I can feel the front bearing is loose!!! And inserting it in to crank case, just wth my finger!!!! Same goes wth my buddy bxr. 2 bxr haveing the same issue!! Bearings are nova that rare correct size
It's the crank !case . Or is it bearings problem????!! Aaaa??!!!
graceku is offline
Old 04-01-2013 | 01:57 AM
  #3043
prowlag's Avatar
Anybody tried nova pipe/header combos with the bxr?? Any insight into what works and what doesn't work?
prowlag is offline
Old 04-01-2013 | 02:23 AM
  #3044
Iv tryed nova manifold wth picco 2099 , 2033 , 2069 , 2034
The 2099 very similar wth 2033. Smooth 2034. Wild and punchy!! The 2069. I like smooth and got high end
graceku is offline
Old 04-01-2013 | 03:03 AM
  #3045
prowlag's Avatar
Thanks. What you think about the 9901/41021 combo?
prowlag is offline
