Like Tree2Likes
RB Concept Engine Thread..
Old 10-29-2012 | 06:36 PM
  #2896
Energyzer's Avatar
Hello guys.
I'm thinking about getting an RB BXR or BX engine to replace my Nova Plus4T. I'm leaning towards the BX since the BXR is a bit expensive. Any feedback on this engine?
My Nova has around 17 liters and is still good, with good compression and no flame outs.
Cheers
Energyzer is offline
Old 10-29-2012 | 08:03 PM
  #2897
jk1152's Avatar
Originally Posted by Energyzer
Hello guys.
Cheers
I have a BX w/ 2097. I like the power. The top and screams. Mid-range power is insane. But I'm not getting the best mileage. On at large open track I'm almost bone dry at 7 minutes 15 seconds. We have 7 minute qualifiers and the last two events I've not finished at least one of them. I'm running 7mm insert. Steel clutch, 4 shoe 6075 aluminum shoes, medium springs. I have 2 gallons on it now. Same car clutch on my B9 with a 2045 pipe got me over 8 1/2 - 9 minutes on a 5 gallon old engine.
Anyone else getting subpar mileage on a BX with the 2097 pipe?
Is there better pipes to try for mileage?
jk1152 is offline
Old 10-29-2012 | 11:26 PM
  #2898
Lille-bror's Avatar
The Danish RB drivers has struggled with flame-out this season. The BX and BXR engines has to have a little richer LSN than e.g. Novarossi. As always its not the engine that is the problem - if you ask me. None of the RB drivers would try Novarossi C6TGC plugs, and I think the plugs also could be a major problem. RB released the V3 plugs in february and Special buggy plugs i August... Why? Due to plug problems?
If you're not running Novarossi C6TGC plugs you shold get the newest RB plugs.
Mileage is average.
Lille-bror is offline
Old 10-30-2012 | 05:47 AM
  #2899
Energyzer's Avatar
Mileage is average.
LSN? Don't know what it means...
What about OS plugs? I've been using them since day 1 on my engines (2 novas), the mileage is average (8.30/9mins) and i don't have flame outs! So is 7mins an average mileage for the BX or we should expect more of it?
Thanks, Tiago
Old 10-30-2012 | 06:02 AM
  #2900
aznitronut's Avatar
Has anybody tried the 2045 pipe on the BX engines?
aznitronut is offline
Old 10-30-2012 | 06:05 AM
  #2901
Lille-bror's Avatar
Thanks, Tiago
LSN = Low speed needle
I' know several guys who is more into RB than I am. The colder plug you are running, the leaner you can run the engine and therefore get better mileage. Hot plug gives more stable idle and a little more torque
Old 10-31-2012 | 10:44 PM
  #2902
camiloro's Avatar
a question, wich one engien have more runtime?? B11 or new BXR? same conditions
camiloro is offline
Old 11-03-2012 | 05:37 PM
  #2903
jk1152's Avatar
Well I'm going to try the 2087.... and see.... Maybe get to try it next weekend.
jk1152 is offline
Old 11-03-2012 | 07:49 PM
  #2904
Default 2087 vs 2097
I recently bought the bxr w out the 2097 pipe. I installed the 2087 pipe that came w the fire 11. The engine is still in breakin stage but it seems pretty good. I'll wont know how 2097 performs cause I don't plan on spending on a another pipe. Can anyone tell me what the difference is in both pipes?
So far after running a liter of Byron's 30. I'm running 200* and getting 8.5mins on a full tank.
dcaprilia is offline
Old 11-03-2012 | 07:55 PM
  #2905
aznitronut's Avatar
How did you like the 2087 on the F11? I been using the 2045, tons of bottom. I tried the 2087 on a C6, same as a B11, it sucked on the C6, really have not heard anybody the likes that pipe.
Old 11-03-2012 | 10:57 PM
  #2906
I have the clocked version of the fire and I used 2087 originally then I tried the ofna 086. Strangely, I liked the power band of the 2087 more. It seems like the 2087 gave me more top end. I have yet to try other pipes w the fire 11.
Old 11-03-2012 | 11:45 PM
  #2907
Maximo's Avatar
try the 2058 on the F11....
Maximo is offline
Old 11-04-2012 | 12:40 AM
  #2908
I think I actually preferred the 053 to the 2058 on my (stock) Fire 11. I've put in a 7mm venturi now to test, so we'll see how that goes. If it doesn't positively affect the way it runs, I think I'll go back to the 053 pipe. I really liked the 053 on the Fire. Never timed it exactly, but it took forever for a tank to empty too.. Seems like it got better run-time than the 2058, and had a somewhat wider tuning window.
Herrsavage is offline
Old 11-04-2012 | 03:27 AM
  #2909
Lille-bror's Avatar
Remember the 053 pipe is not EFRA approved
Old 11-04-2012 | 04:38 AM
  #2910
Maximo's Avatar
I Am not a fan f the 053 pipes....they lack top end on most engines
Maximo is offline
