RB Concept Engine Thread..
#2146
hello everyone, i have a rb concept sport 10. it has less than a 1/2 gallon of nitro through it, its tuned well, but no matter what i do the temps never go above 190 F. what can i do to fix this? I'm kinda new to nitro, so i don't know everything about it. thanks for your help
#2147
#2148
If your never getting the temps up over 190 you either have a bad temp gun or your still very rich. Are you driving it hard or are you just taking it easy? If the engine idles great and does not die you should try leaning the HSN some more and drive it hard. After 5 minutes of hard driving temp it again, then also use a drop of water or spit down by the plug to see if it sizzles. If the water sizzles off your more up around 220-230 and the temp gun is wrong. If it i still cool lean it some more till you have good power and temps up over 200.
#2149
#2153
a query for all that rb engines religiously
which engines , pipes , etc. are the most used in buggy and truggy ?
there is a reason why i ask and it could be beneficial to those who rb products
#2154
B10, B11, Shark10, F11 for Truck
X11. B11 for car but the Shark and B10 are also used in buggy by some.
I have been using the 2087 pipe with a 198 header for truck.
2087 with the 192 header in car.
This newer pipe makes better power than the older 2045 and the fuel mileage is better.
#2155
#2156
PS I left the glowstarter on the plug at 100 celcius and then the idle was smooth and stable..
Daniel
#2157
If it will stay running with the glow starter attached then you have a bad glow plug. I thought I saw you said you alreayd put a new plug in, but it does happen that brand new plugs are bad from time to time.
#2158
yeah this is the fourth glowplug im trying now and it still doesnt work!! so annoying!!!!
#2159
#2160
Chris is the master on this stuff but I'd try a hotter plug and see if that helps.
2Likes
